Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 01-18-2004, 05:07 PM   #1
David Hall
David Hall's Avatar
Profile:
Installation of fantastic Fan
I want to install a Fantastic fan in a 1961 Overlander. 14x14. Can this be done by a novice at sheet metal work. (Me) Does the hole have to be enlarged? What am I looking at as for as complications to install? Thanks for the Help.....Dave....
Dave
David Hall is offline   Reply With Quote
Old 01-18-2004, 07:07 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Dave,
Welcome to the forum. Yes the hole will have to be enlarged on all sides by approx 1/4 inch. The flange from the Fantastic fan will cover with no problem.
The enlargement of the opening can be done with a tin snips. Just be careful of the wires!
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 01-18-2004, 07:22 PM   #3
61Overlander
61Overlander's Avatar
Profile:
I installed my fantastic fan with no problems at all. No I didn't have to enlarge the hole, just a tad of trimming was all that was needed. I did order the airstream curved interior bezel, and that needed a bit of trimming with my dremel. For me the worry was the electrical. I wasnt' sure if my 12v/110 system with no inverter was gonna work. I just wired it to the hot 12v circuit, and can switch it off at the fan or the toggle 110/12v switch on the ceiling. Seems to work fine on the 12 v. Not gonna worry about using it on 110. Mike
61Overlander is offline   Reply With Quote
Old 01-18-2004, 08:04 PM   #4
David Hall
David Hall's Avatar
Profile:
Fantastic Fans
Thanks, to thenewKid 64 , got the answer from Mike, 61 overlander , that I wanted to hear, his is a 61 overlander also and his answer I like best because it sounds like less work to me. thanks to both of you. So I'll go for it and see what happens. Thanks Mike... Didn't try the light covers yet....Dave
Dave
Old 01-18-2004, 10:03 PM   #5
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Threads on FF's
I've saved quite a threads list in textfile for this coming project -- each one adds a little something else!
!!! Dabler's install; click his photos for excellent sequence: Fan-tastic Fan Installation With Photos
Fan-tastic vent - has anyone installed one?
Bug filter for Fantastic Fans
Fan-tastic vent - has anyone installed one? (photos of bezel)
A Few Notes on Fantastic Fan Install
vintage vent install
Checking out wiring locations! 1962 globetrotter gets a/c and a fantastic fan
Old 01-18-2004, 10:52 PM   #6
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings David!
If your '61 has the same Hehr vents as those used in '64 which I believe that it does based upon some notes that I have, you shouldn't encounter any problems with having to adjust opening size - - the photo below demonstrates that the installation was a drop-in as the trim is the original Airstream factory trim that was not disturbed during installation. The Fantastic Vent representatives handled the installation of both of my Overlander's fans at the '99 WBCCI International in Dayton.
Good luck with your project.
Kevin
Kevin D. Allen
AIR #827
Old 01-18-2004, 11:06 PM   #7
61Overlander
Profile:
yep, the original 61 vent was the hehr unit. I saved the vent, minus the cover that my wife drove over. don't ask, it wasn't a funny story. mike
Old 01-19-2004, 06:07 PM   #8
David Hall
David Hall's Avatar
Profile:
Fantastic fan installation
Thanks Mike, Bob and Kevin for the help again. I don't know what I would do without your help, I a novice at this but sure enjoy doing this, I'm putting about 8 Hrs a day into it. Not getting in a hurry with anything because with the cost of ventage parts I sure don't want to mess anything up. Anyway thank you and I've tried to give some Karma to all of you but get no action from the button on the page. Maybe you can clue me in on this also. Thanks....Dave...
Dave
Old 01-19-2004, 06:18 PM   #9
61Overlander
Profile:
oh lord, be careful sending me karma, I was always told it would come back to haunt me.......hold a six pack of beer cold for me instead. Mike
