Old 10-27-2015, 03:41 PM   #1
1993 25' Excella
CLeveland , Ohio
Immediate Assistance Needed for Part
I have a 93 Excella and the ceiling fan outer covers are shot. Vintage Trailer and Inland do not have the plastic cover. I went on a wild goose chase to Camping World (They said they had it) and another place in Akron to no avail.
Does anyone know where I can find a cover?
I need to order one in the next day because I am taking my Airstream to a repair facility Saturday and obviously don't want hole on top. The dimensions (see pic) are 15x15 inches.
It had been painted over by the previous owner:
The brackets look like this:
Thanks in advance!
Akronguy is offline   Reply With Quote
Old 10-27-2015, 08:18 PM   #2
1998 30' Excella 1000
Livingston , Texas
I have what I think is the same cover on my '98. It is a relatively soft plastic. I hand sanded it down (with coarse sandpaper) to virgin material and then painted it with "fusion" spray paint (for plastic). It's been two years, and it looks great. Maybe you can do a better job than the previous owner did.
Siegmann is offline   Reply With Quote
Old 10-27-2015, 09:45 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
That looks like a Hammond vent, like we have in our Avion. Near impossible to find covers. I was able to modify a couple of square covers that I got from CW. Took some handyman skills, but I got it done. Used the same brackets that are on your original covers, used some stainless bolts and cap nuts to fasten those brackets to the new cover (used butyl tape to seal those bolt holes), then had to shave off most of the reinforcing spline that is molded into the new cover so the vent fan would clear when closed. It didn't make a tight seal when closed, but it was close. I have some of those other RV vent covers over the vents, so that hasn't posed a problem.
My long-term solution will be to replace those Hammond vents with Fantastic Fans. Previous owner had already replaced the one over the front living area. I like it a lot!
If at all possible, like a previous poster said: I'd try real hard to salvage the covers you have.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 10-27-2015, 09:47 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Looks like the same cover I have on the '74 Argosy only mine are metal. And they are still in one piece after all of these years.
Old 10-28-2015, 07:24 AM   #5
1993 25' Excella
CLeveland , Ohio
I would like to have been able to salvage them but they crumble at the slightest touch. I wrapped it up in aluminum foil and placed it back because we ar getting a ton of rain in N,E. Ohio.
Old 10-28-2015, 07:26 AM   #6
1993 25' Excella
CLeveland , Ohio
Originally Posted by PaulnGina View Post
That looks like a Hammond vent, like we have in our Avion. Near impossible to find covers. I was able to modify a couple of square covers that I got from CW. Took some handyman skills, but I got it done. Used the same brackets that are on your original covers, used some stainless bolts and cap nuts to fasten those brackets to the new cover (used butyl tape to seal those bolt holes), then had to shave off most of the reinforcing spline that is molded into the new cover so the vent fan would clear when closed. It didn't make a tight seal when closed, but it was close. .
Is this what you used:
https://www.vintagetrailersupply.com...h=852&x=10&y=4
Old 10-28-2015, 07:40 AM   #7
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Depending on how long you can wait, I believe that is the same one I have on my '01 Limited in the front living area. It's being replaced this weekend (10/30-10/31) provided the weather cooperates. You're more than welcome to the whole assembly or just the cover.
I'm replacing the entire thing due to the failure of the little gearbox that lifts the cover and activated the fan. It has finally bit the dust, but other than the rotten gears, the rest of it is in good shape. I am holding onto the interior fixture in hopes I can make it work somehow with the replacement fan.
Let me know if your interested....
toddbecker1@gmail.com
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 10-28-2015, 10:46 AM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Time for a nice fantastic fan?
AtomicNo13 is online now   Reply With Quote
Old 10-28-2015, 10:54 AM   #9
1996 25' Excella
Tillsonburg , Ontario
Looks the same as my '89 Excella. It had aluminum rim and translucent plastic insert. Maybe someone out there with used parts has one ....I think '85 thru '93 were the same model and trim components.
Can anyone step in with the link to used parts guy...I remember seeing it in a previous thread a while back.
Meantime cover with plastic and Duct tape
JCW
JCWDCW is offline   Reply With Quote
Old 10-28-2015, 12:24 PM   #10
1993 25' Excella
CLeveland , Ohio
Found out the part number (921105) and called the Airstream dealer. He wanted 40% more than Out of Doors Mart. Thanks all. No aluminum rim, just all plastic. Aluminum rim would have been nice though.
Old 10-28-2015, 12:37 PM   #11
Gainesville , Florida
Out of doors mart is an AS dealer.
Old 10-28-2015, 12:51 PM   #12
2000 30' Excella
Toledo , Ohio
Airstream had them in the store I bought some a couple years ago
woodfox45 is online now   Reply With Quote
Old 10-28-2015, 01:43 PM   #13
PaulnGina's Avatar
Good Ol' , USA
Originally Posted by Akronguy View Post
In my previous post, I should have said, "Near impossible to find at a decent price."
I had forgotten about those at VTS. No, I didn't use that one. I'm too cheap! Not really..... Just bugs me that folks charge so much for so little.
Old 10-28-2015, 02:24 PM   #14
2017 30' Flying Cloud
Newtown , Connecticut
Try WWW.Airstream supply.com
I hope that helps you.
Eric 28
Eric 28 is offline   Reply With Quote
2001 11.5KBTU Immediate Cycling Al and Missy Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-20-2015 10:28 PM
Your one immediate upgrade / replace / correct on a new delivery IanPoulin Buyer Guidelines 31 01-26-2015 08:09 PM
Immediate need for an inspector in Vienna, Va! Liberator Dollars & Cents 0 06-26-2013 05:01 PM
Need immediate help.. Univolt mercury7 General Interior Topics 4 06-08-2013 05:48 PM
