Old 01-08-2012, 06:34 PM   #1
1967 22' Safari
Carlsbad , California
How to remove Stove Exhaust fan '67 Safari
Name:	Exhaust Fan 2.JPG
Name:	Exhaust Fan 3.jpg
Name:	Exhaust Fan exterior.JPG
Can anyone help me with the removal of the exhaust fan over the stove in my 1967 Safari? I am a new AS owner as of one week ago (no longer an SOB). I have removed all screws underneath but it feels like the vent is solidly attached through the skin. I took off the exterior vent cover but that did not help. Could it be riveted in??
Also, I am going to clean it, sand it, treat the rusted areas and paint it. Any suggestions on paint to handle heat?
The Safari is in good clean original shape so my plan is pull everything out and clean, buff, refinish, new flooring and touch up. I'm sure I will have more questions. Next stop removing and cleaning the original furnace....
Thanks for any help!
New Year Cheers, Tom
worthfam is offline   Reply With Quote
Old 01-08-2012, 07:34 PM   #2
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
Hi Tom,
When I pulled out mine in my '68 GT it was just slid into the vent, a part of the full assembly it was attached to the cabinet itself. I was able to bench the entire assemby, clean it, scuff it and rustoleum it. Came out great. If the fan is inop it is possible to just replace the motor. Go ahead and just tug on it a bit, it should slide out. Mine did. Hope that helps. Remember to find the wiring, usually in the back of the overhead cabinet and separate the leads.
Randy
Randy Gates is offline   Reply With Quote
Old 01-08-2012, 07:36 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Welcome to the Forum
I did the same treatment to my í67 Globetrotter. I remember the vent with the flap and duct came out with the range hood.
I honestly donít remember any extra rivets or screws holding anything to the inner or outer shell.
I do remember it was a very tight fit. I donít think the outer grill is part of the ductwork.
As for paint I used a regular Rustoleum or Kryon almond spray paint. There isnít enough heat coming off the stove to cause any paint issues.
Sorry, thatís all I can come up with for now.
Good Luck,
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 01-15-2012, 02:50 PM   #4
1967 22' Safari
Due to your encouragement that is was just a tight fit, I got aggressive. It was very tight in the interior skin and there was a retainer ring on the outside end of the exhaust tube. As I pulled and rocked it back and forth from inside the retainer ring popped off (I didn't know until I found in lying in the driveway). It is now out so I can get after it!! I will try to post a photo of the re-finished installation.
Cheers, Tom Worth
Old 01-15-2012, 03:27 PM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Good job Tom, I don't remember the fan in the 67 having a retaining ring but it was a tight fit.
Looking forward to more updates.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 02-11-2012, 10:53 PM   #6
1967 22' Safari
Finished!!
1. Stripped, metal prep treated, primed and painted. New fan motor with cleaned blades.
2. Remounted. It was a really tight fit and had to muscle it back in.
3. From exterior
4. With grill and trim ring mounted. Next to put the vent cover back on....
Thanks for the encouragement and help, Tom
ID:	150847   Click image for larger version
ID:	150849   Click image for larger version
Old 02-25-2015, 02:47 PM   #7
1965 22' Safari
Charleston , South Carolina
Anyone know where I can find a replacement fan that fits this same unit? I have a 1965 Safari. Will need to refirb or replace the entire hood/fan. Trying to figure out what to buy. Any suggestions helpful....
Stu
BLTSafari is offline   Reply With Quote
Water in Stove Exhaust Vent Airy Stoves, Ovens & Microwaves 4 01-05-2015 11:31 AM
Remove the stove vent-hood for painting palmtreegirl Stoves, Ovens & Microwaves 0 07-27-2011 07:52 AM
Need help, Kool O Matic exhaust fan destroyed frankfarmer Roof Vents, Skylights & Fans 2 05-06-2011 05:34 AM
2003 safari - how do you remove black water tank? greenrvlife Waste Systems, Tanks & Totes 3 04-08-2011 10:15 PM
2004 Safari leaking around bathroom vent fan DJW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 01-03-2011 04:12 PM
