Old 07-17-2019, 12:00 PM   #1
2015 30' Flying Cloud
Vancouver Island , British Columbia
How do you seal that ?
How do you reseal under the metal shield? Click image for larger version
rintintin is offline   Reply With Quote
Old 07-17-2019, 12:28 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard....👍
You would have to drill out the rivets, I would seal around the edge and over the rivet heads with 3M Extreme Sealing tape..
I have used it on the skylight, FF vents, seams, and antenna.
Lasts well with no leaks in 7 yrs.👍
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 07-17-2019, 12:36 PM   #3
Thanks Bob
Iíll already have used 3m extreme tape for the fantastic fan.
Once you drill out the rivets, how do you put it back together ?
Old 07-17-2019, 12:42 PM   #4
2007 22' International CCD
Olympic rivets (fancy pop rivet) is the only way unless you have tools and access to put in new buck rivets. Iíd leave it and just seal it up as discussion prior.
Old 07-17-2019, 12:44 PM   #5
Old 07-17-2019, 05:19 PM   #6
Originally Posted by rintintin View Post
Thanks Bob
I would leave the rivets...
I did not remove the screws for the FF in the photo, just cleaned VERY well and covered them and the edge with 3m tape.👍
W. H. Auden
Amanamus
"Tahawus"
Old 07-17-2019, 06:58 PM   #7
Paradise , Texas
Yeah, or, leave it be unless you know it's a leaker.
The rivets can be replaced with #10 stainless screws, put dabs of sikaflex into the screw hole, and tighten them up. Dabs of sikaflex over the top of each screw will help later, but is really not necessary.
Crackerman is offline   Reply With Quote
polish and seal or seal and polish kokomoscalls Cleaning, Stripping & Polishing 1 02-06-2014 07:13 PM
Installing exterior lights-to seal or not to seal Belegedhel Lights - Interior & Exterior 7 10-26-2013 07:14 AM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
