Old 06-20-2006, 07:44 PM   #1
1965 20' Globetrotter
mlt , Washington
How do I remove the skylight '65 Globetrotter
Hello,
Our Airstream has a double-crank skylight that needs repair.
Do the rivets need to be hacksawed to get the skylight to be lifted out?
Thanks!!
gseverin is offline   Reply With Quote
Old 06-20-2006, 09:06 PM   #2
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Originally Posted by gseverin
Hello,
Thanks!!
Don't hacksaw. Drill out the rivets to remove the skylight.
....needs repair
- leaking, replacement, what kind of repair?
BTW.... welcome to the forums. You'll find the answers to your many question already posted here, or from one of the many helpful people who have encountered the same questions.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 06-20-2006, 09:20 PM   #3
S C Streamer's Avatar
1964 17' Bambi II
Santa Cruz , California
Images: 13
Is this what you are talking about? The rivets that attach the risers to the roof vent frame.
I need to install a new / old Hehr alumn. vent w/ risers on my Bambi II.
I've been wondering, do I ?
A-drill out the rivet
or
B- hack saw the rivet
Also how do you install this type of rivet?
Mark
S C Streamer is offline   Reply With Quote
Old 06-20-2006, 09:29 PM   #4
Images: 59
If the vent operator is like the one Mark pictured, you don't need to drill out the rivet, or use a hacksaw.
There is an aluminum button at the other end of the outer tube that engages the spiral in the inner part. Carefully pry out the button ( it looks like a rivet) with a knife blade. Then you can lift out the inner workings and the skylight.
Don't lose the button. If you do, you can make a new one by peening a head on a piece of 1/4" aluminum rod, but it's not a fun project.
Old 06-20-2006, 09:45 PM   #5
Darol Ingalls's Avatar
Look on S C Streamer's photo. The "rivet" A is not really a rivet but a pin that fits in a hole in the opener. Simply pry the tab outward and disconnect the round opener. Once you have both openers loose, lift the skylight, turn it sideways and bring it down through the hole. Working on in on a bench is MUCH easier than overhead. The openers themselves are disassembled as Mark describes. Lots of corrosion, but usually fixable. New ones are available from Inland but require some modification to work properly on some older style vent covers. Darol
Darol Ingalls is offline   Reply With Quote
Old 06-20-2006, 10:00 PM   #6
1964 17' Bambi II
Images: 13
I'm replacing the vent lid with operators/risers attached to the existing vent frame.
ID:	22569Click image for larger version
New lid with risers
As you can see the old operator/risers are in bad shape.
Mark
Old 06-20-2006, 10:13 PM   #7
1964 17' Bambi II
Images: 13
markdoane & Darol,
Thanks for the help. That new / old vent lid cost me a pretty penny and I didn't want to screw it up.
Mark
Old 06-20-2006, 10:17 PM   #8
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Do not, and I repeat do NOT, toss your old risers. They can be put in a solution and left to soak for a week or two and can be convinced to work again. Always keep a couple of spares because these are hard to come by.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 06-21-2006, 09:02 AM   #9
mlt , Washington
YES!!!!!!!
I have the assembly that Mark has. I used graphite to work the cranks.
However, the lid is cracked a little. I wanted to remove it to either use
100% silicone or replace. But from what flyfshr said...they are pricey.
Thanks for the info and pictures. Now I see the solution.
gseverin
Old 06-21-2006, 10:32 AM   #10
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If this is the big lid in the front of the Airstream the lid is pricey. Old lids age with sunlight and lose physical properties. I would guess you could glue the old lid if it has a small crack. I replaced my lid with Corrigated Lexan flat sheet. Not stock looking but cheap and more durable than the original lid.
If you are talking about the small square lids in the back, you can replace those with standard lids from Campers World or anybody else.
Old 06-22-2006, 09:13 AM   #11
mlt , Washington
It's the big plastic one in the front.
When you used the Lexan flat sheet, did you screw the riser assmebly onto it?
...and it just lies flat on top of the opening?
Art
Old 06-22-2006, 09:55 AM   #12
Attachment 22568
or
Mark
There are two holes in the operators.
The small pins or studs that are on the bracket, goes into those holes, holding the operator in place.
DO NOT DRILL THOSE PINS OUT.
Simply spread the bracket apart a little with a screwdriver and the operator will drop out.
The holes in your operators are in the same location as those in the operators that we have made.
Photo attached.
Old 06-22-2006, 10:03 AM   #13
Images: 70
Photo attached.
Andy in your picture the two holes in the "hinged" part of the opener is what I was talking about drilling the rivets out of. (where the operator attaches to the dome) Is that what you are referring to? On my '64 those are riveted to the dome, hence my direction to drill them out - however mine is a replacement from a P.O. somewhere along the line. (and it leaks where they re-attached the new dome with pop-rivets and some sealant over that)
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 06-22-2006, 10:26 AM   #14
mlt , Washington
The hinges that attach to the plastic skylight lid are ok. I didn't want to
saw those. I plan to spread the bracket apart as suggested a couple of times above.
BTW Andy, what do new metal rectangular vents cost for that skylight opening....at Inland RV Center?
Art
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 06:03 PM
1964 GlobeTrotter InsideOut 1960 - 1964 Globetrotter 3 09-29-2005 11:56 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 09:16 AM
