Old 04-29-2006, 12:37 PM   #1
1970 31' Sovereign
palm springs , California
Help Need roof vents for 1970
Well we need the vent covers that screw up and down for our Land Yacht We need three, one in bathroom, one in kitchen and one over fan in living room...any suggestions....where did you get yours?
happydaze is offline   Reply With Quote
Old 04-29-2006, 03:23 PM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
skylights
hi- for my '72, which had one metal and 2 cracked plastic lids, I just picked up 3 new "standard" vent lids from an rv store, they were maybe $11 a piece, sort of a milky-opaque white, they let light through nicely. But I had to take the 2 metal mounting arms off of the inner assembly in the coach, rivet and seal them to the new lid, then re-mount the whole thing. A bit of work but certainly cheaper than some alternatives and they fit fine, though without the radiused corners of the aluminum frame on the coach. I then used some 1/2" foam gasket material, self-stick, on the alum. frame to seal them completely when closed.This might work for you too, if you don't mind not being factory original. - tim
tphan is offline   Reply With Quote
Old 04-29-2006, 08:12 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Vent repair for 60's trailer.
I used a similar stock vent from a SOB for my rear vent. I glue another piece of clear plastic on the inside of it to reinforce it and give a little insulation and sound dampening. I also have been know to make a flat vent cover out of corregated Lexan sheet stock. Even hail can not break this one.
Old 04-29-2006, 11:17 PM   #4
surferstyler's Avatar
1972 27' Overlander
San Juan Capistrano , California
Vent covers
Inland RV makes their own from the orginal. Call them!
surferstyler is offline   Reply With Quote
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
Replacing roof vents JAD Roof Vents, Skylights & Fans 10 04-15-2004 09:37 PM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
Gaskets, vents, etc... Chuck Windows & Screens 3 10-27-2002 02:18 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
