Old 04-29-2015, 06:11 AM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
HELP - How to turn on vent fan?
I cannot locate the switch to activate this vent fan in my 54 FC. I thought perhaps the pull chain that opens the exterior vent would activate it but it is a separate device. Fan wires enter the wall headed upward but there is no obvious switch in the cabinet above or on the ceiling. What am I missing?
ID:	237380   Click image for larger version
BambiTex is offline   Reply With Quote
Old 04-29-2015, 08:56 AM   #2
richw46's Avatar
Lexington , Kentucky
Any chance a fuse is blown or missing?
Are you able to get an owner's manual from AS support?
Is there a group of switches somewhere else, like at the door? Maybe the fan switch is part of those.
When you open the vent slowly, do you hear a click, like a switch is activating? Maybe the switch is bad
When the vent is open, have you checked for power at the fan? Maybe the fan is bad or isn't grounded (I'm assuming a 12vdc fan).
If it were me, I'd run a jumper wire to the fan to confirm the fan actually works. Then I'd inspect the mechanism that opens the vent to see if there is a switch that closes when the vent has opened. Maybe the vent isn't closing that switch, not traveling far enough.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 04-29-2015, 09:06 AM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
All fuses are good (old school screw in glass type).
No manuals exist for 1950's trailers.
The only switch I have found in the trailer is by the door and controls only the porch light.
I have taken apart the housing and the pull chain and vent opening are not connected to anything electrical.
I plan to bench test the fan but wires are sealed and need to be cut in order to remove the fan. Simplest test would be to turn on the d*** switch if only I could find it :-)
Old 04-29-2015, 10:04 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There should be a switch that is activated when the lid is opened. Check between the frame and the lid for the switch, which is probably stuck in the closed position.
Old 04-29-2015, 12:19 PM   #5
Gainesville , Florida
Dies it have a flap outside that needs to be open? Before the fan will run? Jim
Old 04-29-2015, 12:23 PM   #6
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Flap open with a pull chain. Will search interface between frame and lid.
Tks.
Old 04-29-2015, 02:03 PM   #7
richw46's Avatar
Tks.
That's what I was thinking, a limit switch. When the vent is pulled open the edge comes in contact with a momentary switch. There's a connection only when the vent blade presses on it. Release the chain, blade retracts and the switch opens.
Switch may be bad (or bad connection)
Vent blade may not be reaching the switch to close it; adjust the vent blade or switch to bring them closer together.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 04-29-2015, 08:57 PM   #8
'78 Sovereign
1978 31' Sovereign
Santa Rosa Beach , Florida
These type of vent fans were common in older mobile homes and are spring loaded to open when you release the chain. There should be a switch that is likely stuck from grease buildup and may be visible behind the flap from outside.
frankrightbrain is offline   Reply With Quote
Old 04-29-2015, 09:42 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yeah.. I was born in '54.. lost the instructions a looooooong time ago.. =)
Hope you figure out why it isn't running... did it ever?
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-30-2015, 07:41 AM   #10
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Not sure
Not since I bought it in January. Looks original.
Old 05-04-2015, 06:32 AM   #11
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Doa
OK, I found the switch and the problem. Switch is good. Fan gets voltage but wiring to fan disintegrated and pulled out of motor. Pretty sure the whole thing is toast. I need either a new motor (to which I can mount the old blades) or a whoel new fan. Opening is 8 inch diameter, fan blades are 7 inch. 110 volt. Ideas?
Old 05-04-2015, 10:01 AM   #12
richw46's Avatar
110 vac? I'm surprised, would have thought it was 12 vdc. How much trouble to convert it?
You can probably find a similar fan online. Get the specs off the old one if you can, search by HP and RPMs if you can. Measure the width and depth, you may have to buy an old fan off of eBay and take the motor out of it.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 05-04-2015, 10:04 AM   #13
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
110 because my old trailer has no 12 volt system.
Was hoping to find a nameplate with HP, RPM, etc. but no such luck...
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? stc cigar Airstream Classifieds 0 02-19-2014 08:45 AM
Google Turn-by-Turn Navigation techiej Electronics & Connectivity 19 12-27-2012 05:55 AM
Fan-Tastic Vent Fan roadliner54 Our Community 2 07-11-2011 11:14 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Fridge Fan won't turn OFF clancy_boy Refrigerators 7 09-04-2007 08:55 PM
