Old 03-07-2005, 07:46 PM   #1
58BUBBLE's Avatar
Hehr vent repair?
I was able to free up my lifters and they are working great. Unfortunately I am missing the small hinge that attaches to the lid on one of the lifters. Is there another type of hinge I could possibly use? What if I took the hinge off the other side and just attached the lifter rods straight to the lid with epoxy or something? That might be to difficult to raise though. I will be using an aftermarket lid since mine is missing.
58BUBBLE is offline   Reply With Quote
Old 03-07-2005, 08:35 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
The original hinge allows for freedom of movement in case you would want to open one end or the other or if you don't open both ends at the same time. Leaving the hinge out and making it rigid would be a problem. I don't have an extra hinge or I would help you out.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-07-2005, 11:19 PM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Send a message via Skype™ to uwe
How'd you do that? I've soaked mine in every possible solvent, and they're still frozen solid...any ideas?
Uwe
www.area63productions.com
uwe is offline   Reply With Quote
Old 03-08-2005, 11:07 AM   #4
Images: 59
Uwe,
I think you need to remove the pin. There must be something jammed up in the spiral track. You pry it out with a jackknife.
Don't lose it!
Old 03-08-2005, 04:38 PM   #5
58BUBBLE's Avatar
I was able to free mine up with Liquid wrench.
Old 03-08-2005, 06:10 PM   #6
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Ok, I pried the pins out. Still no move.
I soaked the newfound acces hole with some penetrating oil, will see what happens tomorrow.
Thanks for the tip!!
This just might work.
Uwe
Old 03-08-2005, 08:35 PM   #7
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Images: 18
Send a message via AIM to Andrew Selking
I had one that was stuck and would not turn so I removed it from the lid then popped off the cap at the square end and unscrewed the cover off of it. Then I took a torch and lightly applied heat to it and got it to turn . If you apply too much heat you will melt it. Now just put a light coating of grease on once a year to keep them free.
Andy sells a replacement one if you can't get yours to work.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 09-18-2006, 09:32 PM   #8
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
My lifters work great. But I'm trying to remove them to paint them and also to attach the vent cover to it.
What's the best way to get them off the trailer?
-Tim
1960 International Ambassador 28'
2001 Silverado 2500HD CC 6.0L 4.10
Check out my book: Restoring a Dream
Check out my Airstream book for kids!: Airstream Adventures
theVAP - Airstream Podcast
Safari Tim is offline   Reply With Quote
Old 09-18-2006, 09:38 PM   #9
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Hi Tim ~
There are two arms that come out from the bracket attached to the vent frame that hold the lifters in at the bottom. Pry these apart with a flathead screwdriver. They are quite rigid but can be convinced to comply.
FF
Old 09-18-2006, 10:01 PM   #10
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thanks Brad.
If we are thinking about the same thing, I tried that but could not get the part that the handle attaches to up and out of the mount.
Does it just need a little more convicing
-Tim
Old 09-19-2006, 05:52 AM   #11
Images: 59
Tim,
You're prying in the wrong place. Put the screwdriver between the little arm coming off the frame and the bottom of the cylinder. It's about 90 degrees from where your arrow points.
It looks like it's a through rivet, but it's not. It's just a pin like Brad says.
Here's a picture with the operator removed.
Old 09-19-2006, 06:01 AM   #12
S C Streamer's Avatar
1964 17' Bambi II
Santa Cruz , California
Images: 13
Originally Posted by Safari Tim
Thanks Brad.
Hi Tim,
Slip a small screwdriver into the space marked " B "...
pry outward until the pin marked " A " clears the riser assembly, repeat on other side and on 2nd riser.
Mark
1964 17' Bambi II
2005 Dodge 2500 PowerWagon -5.7 Hemi
WBCCI #4207
AIR #11485
"you don't need a weatherman to know which way the wind blows" ~bob dylan
S C Streamer is offline   Reply With Quote
Old 09-19-2006, 11:23 AM   #13
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Hi all,
This issue doesn't affect me, but I'm always impressed by the helpful responses found here, diagrams and all! Keep it up.
Old 09-19-2006, 11:24 AM   #14
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Perfect guys!
It just fell out nicley. Works good when you do it the right way.
Thanks a bunch!
-Tim
Old 05-09-2010, 10:44 PM   #15
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
hehr vent knobs
here's a simple question--how doe the knobs come off an herh vent? i have an original fan i want to install and don;t want to break the knobs when i remoove them. cheers
the544man is offline   Reply With Quote
Old 05-09-2010, 10:48 PM   #16
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Are you referring to the aluminum T handle knobs? If so, they pull straight down and are held in place similar to a socket and ratchet with the little ball under tension on one side of the square shaft on the lifter itself.
FF
Old 05-10-2010, 07:43 AM   #17
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Boy! This sure helped me out today!
I'm trying to get the Cloud ready for a trip to ABQ for the restoration rally. My aft vent needed help and I was at a loss 'till this thread . Thanks Guys.
Old 05-10-2010, 08:28 AM   #18
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
t handles knobs on hehr vent
i'll try pulling harder while sticking somthing into the tiny hole to release it? sounds like that's the method. if it's like a socket it should come out pretty easy i would think. maybe i need to spray in some pb blaster and let it soak for a while. thanks for your input--ted
Old 05-10-2010, 06:43 PM   #19
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
It may just be all gunked up. It should come out with a downward pull. Some pentetrating oil may help.
FF
Old 05-10-2010, 08:12 PM   #20
CaptainJones's Avatar
1951 21' Flying Cloud
Western , Kentucky
Be careful. I broke a shaft by prying to hard and too fast.
Greg
Greg Jones
CaptainJones is offline   Reply With Quote
Vintage Hehr vents silverhawk Roof Vents, Skylights & Fans 6 07-18-2005 02:37 PM
Calling any CALIFORNIA AS's.. Chitown AirStreamers Our Community 0 05-28-2004 12:05 PM
Calling ChicagoLand Airstreamers Chitown AirStreamers General Repair Forum 5 05-19-2003 03:13 PM
