03-07-2005, 07:46 PM
Hehr vent repair?
I was able to free up my lifters and they are working great. Unfortunately I am missing the small hinge that attaches to the lid on one of the lifters. Is there another type of hinge I could possibly use? What if I took the hinge off the other side and just attached the lifter rods straight to the lid with epoxy or something? That might be to difficult to raise though. I will be using an aftermarket lid since mine is missing.
03-07-2005, 08:35 PM
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
The original hinge allows for freedom of movement in case you would want to open one end or the other or if you don't open both ends at the same time. Leaving the hinge out and making it rigid would be a problem. I don't have an extra hinge or I would help you out.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
03-07-2005, 11:19 PM
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
How'd you do that? I've soaked mine in every possible solvent, and they're still frozen solid...any ideas?
03-08-2005, 11:07 AM
Uwe,
I think you need to remove the pin. There must be something jammed up in the spiral track. You pry it out with a jackknife.
Don't lose it!
03-08-2005, 04:38 PM
I was able to free mine up with Liquid wrench.
03-08-2005, 06:10 PM
418
1974 29' Ambassador
Yucca Valley
Ok, I pried the pins out. Still no move.
I soaked the newfound acces hole with some penetrating oil, will see what happens tomorrow.
Thanks for the tip!!
This just might work.
03-08-2005, 08:35 PM
My Grandparents Airstream
2007 28' Safari SE
Hillsboro
I had one that was stuck and would not turn so I removed it from the lid then popped off the cap at the square end and unscrewed the cover off of it. Then I took a torch and lightly applied heat to it and got it to turn . If you apply too much heat you will melt it. Now just put a light coating of grease on once a year to keep them free.
Andy sells a replacement one if you can't get yours to work.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
09-18-2006, 09:32 PM
a.k.a. Ambassador Tim
1960 28' Ambassador
Northern
My lifters work great. But I'm trying to remove them to paint them and also to attach the vent cover to it.
What's the best way to get them off the trailer?
09-18-2006, 09:38 PM
1959 24' Tradewind
Phoenix
Hi Tim ~
There are two arms that come out from the bracket attached to the vent frame that hold the lifters in at the bottom. Pry these apart with a flathead screwdriver. They are quite rigid but can be convinced to comply.
FF
09-18-2006, 10:01 PM
1960 28' Ambassador
Northern
Thanks Brad.
If we are thinking about the same thing, I tried that but could not get the part that the handle attaches to up and out of the mount.
Does it just need a little more convicing
09-19-2006, 05:52 AM
Tim,
You're prying in the wrong place. Put the screwdriver between the little arm coming off the frame and the bottom of the cylinder. It's about 90 degrees from where your arrow points.
It looks like it's a through rivet, but it's not. It's just a pin like Brad says.
Here's a picture with the operator removed.
09-19-2006, 06:01 AM
1964 17' Bambi II
Santa Cruz
Originally Posted by Safari Tim
Thanks Brad.
Hi Tim,
Slip a small screwdriver into the space marked " B "...
pry outward until the pin marked " A " clears the riser assembly, repeat on other side and on 2nd riser.
Mark
1964 17' Bambi II
2005 Dodge 2500 PowerWagon -5.7 Hemi
WBCCI #4207
AIR #11485
"you don't need a weatherman to know which way the wind blows" ~bob dylan
09-19-2006, 11:23 AM
West of Fort Worth
Hi all,
This issue doesn't affect me, but I'm always impressed by the helpful responses found here, diagrams and all! Keep it up.
09-19-2006, 11:24 AM
1960 28' Ambassador
Northern
Perfect guys!
It just fell out nicley. Works good when you do it the right way.
Thanks a bunch!
05-09-2010, 10:44 PM
1956 16' Bubble
Dallas
, Oregon
hehr vent knobs
here's a simple question--how doe the knobs come off an herh vent? i have an original fan i want to install and don;t want to break the knobs when i remoove them. cheers
05-09-2010, 10:48 PM
1959 24' Tradewind
Phoenix
Are you referring to the aluminum T handle knobs? If so, they pull straight down and are held in place similar to a socket and ratchet with the little ball under tension on one side of the square shaft on the lifter itself.
FF
05-10-2010, 07:43 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Boy! This sure helped me out today!
I'm trying to get the Cloud ready for a trip to ABQ for the restoration rally. My aft vent needed help and I was at a loss 'till this thread . Thanks Guys.
05-10-2010, 08:28 AM
1956 16' Bubble
Dallas
, Oregon
t handles knobs on hehr vent
i'll try pulling harder while sticking somthing into the tiny hole to release it? sounds like that's the method. if it's like a socket it should come out pretty easy i would think. maybe i need to spray in some pb blaster and let it soak for a while. thanks for your input--ted
05-10-2010, 06:43 PM
1959 24' Tradewind
Phoenix
It may just be all gunked up. It should come out with a downward pull. Some pentetrating oil may help.
FF
05-10-2010, 08:12 PM
1951 21' Flying Cloud
Western
, Kentucky
Be careful. I broke a shaft by prying to hard and too fast.
Greg
Greg Jones
