Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 06-06-2005, 07:38 AM   #1
Hehr roof vent question
Does the operator for these vents pop into the bracket holder by aligning the two studs protruding from the bracket with the two holes in the ring of the operator itself? Mine keeps popping out. It is a s though the bracket won't squeeze tightly enough to hold the operator in place. I was was considering using a rivet to replace the studs. Is this the way it was originally designed? Has anyone solved a similar problem by doing this or something else?
pgajkowski is offline   Reply With Quote
Old 06-06-2005, 08:25 AM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
The lifter for the vent goes into those two small studs. That's the way it was designed. Maybe with the lifter out, you cound force the two arms closer together and put the lifter back in. It is possible the arms have lost their tension over the years because of the vent being taken off so many times.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Repairing roof vent covers? JohnGalt48 Roof Vents, Skylights & Fans 21 04-15-2007 04:45 PM
Roof Vent Covers Dwight Roof Vents, Skylights & Fans 2 10-13-2003 10:16 AM
Roof Vent Original? pepper48 Roof Vents, Skylights & Fans 6 11-09-2002 05:44 AM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
