Old 06-14-2011, 08:09 AM   #1
1965 17' Caravel
Roseville , California
Hehr Popup Vent, LaDeau Operator Removal
I searched and didn't find anything specific on my question, so here's a new thread. How do you remove the LaDeau knobs from the operators? One side cranks up fine, the other side will rotate but not jack the vent up. I took a look at the side of each knob and it looked like there were two allen-head set screws on the knob, but after a closer look they don't look to have set screws. I was a little reluctant to force them as I have heard the parts are a little pricey or scarce.
Thanks.
cal.caravel is offline   Reply With Quote
Old 06-14-2011, 08:59 AM   #2
1960 24' Tradewind
Golden Valley , Minnesota
just pull them off...
My 1960 vent handles have the same two holes per handle- there's nothing in the holes... just rock and pull down and they will pop off (there's a spring loaded ball in the shaft that holds them on and aligns with one of the holes).
-Sal
SalandViv is offline   Reply With Quote
Old 04-30-2018, 02:02 PM   #3
1958 22' Caravanner
Tempe , Arizona
Pulling the knobs off
Thanks.
Did Sal's response work with just rocking and pulling them off? If so can you put them back on once you did this we have the same problem not knowing how to get them off to change the gasket.
Connie F is offline   Reply With Quote
50's Hehr roof vent lifter arm rivet tool vintageair Roof Vents, Skylights & Fans 12 06-29-2011 01:37 PM
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 03:44 PM
Fitting a Nicro vent to the existing Hehr vent Globie64 Roof Vents, Skylights & Fans 8 03-17-2011 02:35 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
