Old 07-31-2009, 05:01 AM   #15
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
For me the quest for replacement outer vent cover springs has ended. A local Ace Hardware store stocked an extension style spring that is the right wire size and the right coil size. Cost was $2.00 each. With the help of a MAPP gas torch the ends were straightened until the right number of turns remained and the legs were at the requisite 90 degree angle. After reheating, the spring was then quenched in cold water to re-establish the temper and set the memory. Then the legs were cut to length. This is the result compared with the remnant of an old one.
Installed they look like this.
The only difference is that on the original one would be a left hand winding and the other a right hand so that the leg against the door would be on the outside on both sides. Functionally there is really no difference and I'm happy. I still think someone should offer these for sale.
dieseleagle is offline   Reply With Quote
Old 08-01-2009, 08:50 PM   #16
BarryIowa's Avatar
Polk City , Iowa
Very nice final result!
BarryIowa is offline   Reply With Quote
Old 08-01-2009, 10:03 PM   #17
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Very nice work!!
Are you going to market those modified springs? I know a guy who needs them for a 63 safari .
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 08-03-2009, 05:34 AM   #18
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Thanks. Necessity is the mother of invention. I put a digital caliper on it and the corrected measurements would be: wire diameter - 0.063; OD - .415; ID - .27; Axial length - .534; wraps - 8; leg length - 2 inches.
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 04:00 PM
replacing 71 TW galley tambour Lumatic Cabinets, Counter Tops & Furnishings 6 01-25-2009 06:33 AM
galley vent fan LHall Lights - Interior & Exterior 0 08-10-2007 12:09 PM
Galley Puzzle Cat Cabinets, Counter Tops & Furnishings 9 10-07-2006 05:26 AM
Galley plumbing Warren W. Wiley Fresh Water Systems 8 06-17-2003 09:25 AM
