Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 04-08-2013, 11:07 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Front vent fan not shut off
Our 1999 Excella front vent turns on when vent is cranked open. When closing it should shut off and usually does.
On occasion it doesn't shut off. After many crank open/close cycles it will shut off no matter how far I crank open or closed it fails sometimes.
Is there a diagram of the vent or idea from the group on what it might be that is causing!
Thanks in advance!
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-09-2013, 04:55 AM   #2
Retired.
. , At Large
That is an easy one. The switch is circling the drain, and needs to be replaced before it fails completely.
Old 04-09-2013, 06:30 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thanks!
Channing
WBCCI# 30676
Old 04-09-2013, 08:36 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Anyone with diagram of this vent ?
Channing
WBCCI# 30676
Old 04-09-2013, 09:35 AM   #5
daveswenson's Avatar
2012 28' International
Olympia , Washington
I don't have a diagram, but there is a switch on the hinge side of the vent to turn off the fan when the vent closes. It can get sticky. I had to clean and lube mine yesterday. Fan wouldn't turn on.
That would be the first thing I would check.
It can be accessed by removing the cover from the bottom of the vent. It looks like a pin sticking upward on the hinge side.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-11-2013, 06:37 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thanks for the tips!
Channing
WBCCI# 30676
