Old 09-11-2006, 10:15 PM   #1
camperski's Avatar
1969 27' Overlander
Pickens , South Carolina
Front Exhaust Fan 69 Overlander
Mine has a 3 position switch. What are the three positions currently they are;
- fore - fan on and exhausting
- mid - nothing
- aft - nothing
is this fan supposed to be 2 speed? reversible?
my bath fan is 2 speed and works great!
-"Nothing is particularly difficult if you break it down into small jobs" - Henry Ford
-"just because the monkeys off your back, doesn't mean the circus left town!"
14854
www.pickenscountycampers.com
camperski is offline   Reply With Quote
Old 09-12-2006, 08:58 PM   #2
camperski's Avatar
1969 27' Overlander
Or do I forget this being original and install something new?
14854
Old 09-12-2006, 10:01 PM   #3
69 Silverback's Avatar
1969 27' Overlander
Firth , Nebraska
fan switch
your fan switch is set up to operate the fan at 2 speeds. One way , it goes through a resistor for slow speed. center is off. other way is high speed. Most likely the resistor is bad or a broken conection
good luck
69 Silverback is offline   Reply With Quote
Old 09-13-2006, 07:34 PM   #4
camperski's Avatar
1969 27' Overlander
thank you silver back! I have a few friends that may be able to handle that! I assume the resistor is located in or near the fan assembly? Really excited as this 69 began going back together this week.
14854
Thinking of Buying '72 Overlander Joe C 1972 Overlander 16 07-20-2005 06:01 AM
Vent Covers front two tmeagle1 Roof Vents, Skylights & Fans 1 05-15-2004 08:17 AM
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 06:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
