Old 12-01-2011, 02:44 PM   #1
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
Fridge Vent Removal - how?
How do I get the roof vent for the refrigerator off? I've got a major leak in the roof vent hole.
I know I need to punch and drill out the big rivets.
1. What size drill bit should I use?
2. What type of rivets are these?
3. Suggestions for this repair? Upgrades, etc?
thanks
ID:	146302   Click image for larger version
MrJ is offline   Reply With Quote
Old 12-01-2011, 02:49 PM   #2
thanks
Use a #30 to drill out the "buck" rivets.
Reinstall by using a #21 drill bit for the olympic rivets.
Add a little sealer to the rivet shank, before you insert it into the hole.
What's to repair?
The reefer vent cover is very soft. That dent can easily be pushed out.
Then you don't need any drill bits.
Old 12-28-2011, 09:25 PM   #3
Antipode's Avatar
1975 Argosy 28
Spicewood , Texas
Fridge Chimney
My '75 28' owners manual says to check the chimney is clear. I haven't look from out in only from access door up. I'm worried the cap is not mud dobber proof for next summer.
Fridge works fine now on electric or gas. Any sage advice to avoid future issues or maintain the ammonia plumbing?
Work Camping, Reno is $4,100 and climbing.
Antipode is offline   Reply With Quote
Hehr Popup Vent, LaDeau Operator Removal cal.caravel Roof Vents, Skylights & Fans 2 04-30-2018 02:02 PM
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 11:14 AM
Screen inside fridge vent cutterbug Exterior Storage Compartments & Access Doors 3 07-19-2011 08:08 PM
New fridge on the Outs? skydiva Refrigerators 2 07-04-2011 03:04 PM
Can you vent a battery through the fridge vent? Mike&Ali Batteries, Univolts, Converters & Inverters 22 03-07-2011 09:06 PM
