Originally Posted by hickam
I want to put a fantastic or similar thermostat controled fan in the front roof vent of my '66 Soveirgn. I heard people do this all the time, and right now it has a chimney from a wood stove (previous owners!). Problem is that the Fantastic vents are 14"X14" and the vent openning is only 12". Any ideas?
Thanks!!!
Can be done, I just did it. Make sure you have a good right hand and left hand aircraft shears before you start. Don't buy cheap ones you'll regret it.
I had to frame my opening in. U-channel or wood block either will work.
Don't be afraid of using your Vulcum sealant.
Did you get the Airstream trim for the inside? if not oder it, can't live without it.
Do you have power available at that spot, fishing in a power run it tough, but can be done between the hoops.
Ready now, cut.
