Old 03-19-2018, 05:19 PM   #1
Bellaire , Texas
fantastic vent install
own 2006 safari se/le switching out vent in front bedroom for fantastic vent have removed vent and trying to wire new fan to run without bedroom lights on. I am using power off one of ceiling lights but no power unless I turn switch on to lights in master. Do I need to get power from somewhere else ? and if so where? surely there must be a way to get power without lights on. Any help greatly appreciated. there was no power prewired for a switch out.
Bigeddie58 is offline   Reply With Quote
Old 03-19-2018, 05:24 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Did your old vent have a fan? Not sure about 2006 but does the wiring harness runs down the ceiling curbside of the ceiling vents?
Lumatic is online now   Reply With Quote
Old 03-19-2018, 06:10 PM   #3
Bellaire , Texas
no fan it was just a hand crank vent no wiring harness. plan b wire the vent and remove bulbs, why wouldn't airstream locate 12v power for future upgrades?
Old 03-19-2018, 06:36 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
When you say above you removed the old vent did you also remove the vent frame that is attached to the roof?
Old 03-19-2018, 09:08 PM   #5
Bellaire , Texas
yes all i have now is a hole in roof waiting for install of new fantastic vent. dry fit new fan no problems. thinking i might have to fish a wire to vent fan in shower. that should be hot weather fan is on or off.
Old 03-20-2018, 08:40 AM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
On my 70s and 93 AS the wiring harness was in the ceiling, curbside right next to the vent opening. I'm surprised that nobody else has chimed in. Maybe call Airstream or an Airstream dealer to find the easiest access.
Old 03-22-2018, 08:23 PM   #7
Bellaire , Texas
wound up fishing a wire to exhaust fan in shower. can now run fan with lights off in bedroom.
Old 07-10-2018, 03:03 PM   #8
Denver , Colorado
I'm in the middle of the exact same project, except Maxxair Fan. Same trailer it seems too!
How did you fish the wire to the shower fan? There is a rib between the bedroom and the shower, and I'm not sure how to get around that (Through it?) Did you have to remove any interior aluminum panels? Perhaps the wood panel that has the wall switch on it?
Thanks!
-Paige
Jump, and the net will appear.
Papatango is offline   Reply With Quote
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 02:01 PM
Maxxair Vent cover install on OEM vent perryg114 Roof 1 08-29-2015 10:19 AM
'76 Argosy have vent pipes at roof (nicro vent install idea) BrianD. Waste Systems, Tanks & Totes 6 11-08-2014 07:28 PM
How do I install vent covers over my vent covers? bigjohn Roof Vents, Skylights & Fans 1 07-29-2010 04:34 PM
Which Fantastic Vent did you install? adwriter73 Roof Vents, Skylights & Fans 18 06-25-2010 11:12 AM
