Old 08-05-2011, 12:22 PM   #1
1980 31' Excella II
Ocean View , Delaware
Fantastic Vent Help Needed
We are thinking seriously about installing 2 fantastic vents in our 80 Excella. We priced it at the nearest authorized Airstream Dealer and the 2 fans were $612/ total and the installation was $270/each! Their prices seem a little high, especially the installation charge. We found an authorized Fantastic Vent dealer nearby, but they won't work on Airstreams.
I think I read here that they are sometimes available at Rally s and we could have them installed then. Or maybe you know of somewhere with better pricing in the mid atlantic area? We live in lower Delaware.
Thanks for your help!
Sue and Ran
Disneysue925 is offline   Reply With Quote
Old 08-05-2011, 12:31 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Cough.... choke.....
Old 08-05-2011, 12:38 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
THe Fantastic vent folks are usually at the International and also Florida state. I have installed my own and would say it took an hour each. Just need to find a source of 12 volts, and chances are it is already there
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 08-05-2011, 12:39 PM   #4
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Wow I am in the wrong business. You can buy them on line and with help from this sight do it for less than half of that. It should only take an afternoon to do both.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 08-05-2011, 12:40 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Fan-Tastic Fan Vent
Old 08-05-2011, 12:52 PM   #6
1980 31' Excella II
Wow!! Just priced the ones we want on the VTS site (Thank you Ganglin!) and they are $209/each!! I don't mind paying a reasonable mark up on an item but now both the item and installation pricing seem crazy.
I'm not sure I can convince Ran to give installation a try. I think we've both been so frightened by the leak damage threads that we're afraid afraid to "open" the shell in any way.
Sigh
Old 08-05-2011, 01:07 PM   #7
Elkhart , Indiana
Do a YouTube search. There was a nice video that shows the install well
. It was done by one of those car restoration shows so it is pretty good quality. If I were at a real computer I could post you a link. The install is not difficult and you will get to know your trailer better.
Mike
Have a great day!
Old 08-05-2011, 01:13 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wow...it would be nice to know who the "nearest" is.
I know it's a dealer.... but thats hard to swallow.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 08-05-2011, 01:30 PM   #9
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If you get them from Vintage Trailer supply they have them with silver hatch covers to match the trailer. Also a curved trim piece for the inside that matches the contour of the roof. By all means get the one with the rain sensor. It is a life saver, trust me.
Installation is took me better part of a day so the quote from the dealer isn't all that bad considering labor cost now per hour. Mine had 40 years of goop and junk covering the rivets. Took forever to just get down to the rivets, then you have to drill them out, then you have to slightly enlarge and square off the opening both inside and out. If you do it yourself, the pro's recommend not using the foam gasket that comes with the fan. Rather lay down a good bead of vulkem and bed the base in that. Also, get some stainless steel washers and put under the head of the screws. That will distribute the load over a larger area and help keep the base from cracking. Then cover the screws with a dab of vulkem. That is how I did mine and have had no leaks. I love it.
If you don't have 12 volts close to the outlet installation will be much harder.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-05-2011, 03:32 PM   #10
Gainesville , Florida
Somke of the fans have features that make them a lot morexpensive. jim
Old 08-05-2011, 04:49 PM   #11
1980 31' Excella II
Screws vs Rivets
So, do you use screws or rivets to fix it to the roof? Bruce's advice seems good--and frankly easier--than using rivets, like they do in the Classic Rides video. Pros/Cons????
Thanks again to everyone!
Sue and Ran
Old 08-05-2011, 05:09 PM   #12
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I put 2 FF's in my AS last year. Relatively easy job. I was replacing 2 fans that I removed so the 12v power was already in place. I used screws to fasten them down. It was mentioned earlier about the rain sensor's. Get them, they work, and allow you to have the use of the fan even when you are away, if you want. Not difficult but you do have to take care when working on the roof. But a relatively easy job.
You will also need a couple of sheet metal shears. The FF's are slightly oversized from the original AS fans and you need to do a little trimming. Shears come in left handed / right handed & straight. It goes easier if you have each time. But I'm sure it can be done without.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 08-05-2011, 06:03 PM   #13
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
can tin snips be used to trim the openings?
desertair27 is offline   Reply With Quote
Old 08-05-2011, 06:17 PM   #14
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The units from VTS come with a great template to make the cuts. Snips are fine. I used a jig saw. I tapped 12 volts from the nearby light fixtures in my '81. A couple of hours will be plenty for both fans.
Order 4 tubes of trempro(new name for vulkem) and you will have some left for other sealing needs.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
fantastic fan
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 03:44 PM
Wiring for Fantastic Vent Air Cruiser Roof Vents, Skylights & Fans 6 05-04-2011 03:16 PM
Fitting a Nicro vent to the existing Hehr vent Globie64 Roof Vents, Skylights & Fans 8 03-17-2011 02:35 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
