Old 07-03-2012, 05:25 PM   #1
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Fantastic Vent - fan not working
Wondering if anyone can help as Fantastic Vent are closed till the 6th and I live by my vents for airflow.
It is my rear vent fan. Rainsensor model.
fuse good
lifter arm motor good
on off switch good
But fan will not come on - not in IN or Out mode. Fan can move freely so no obstruction -
Not wet so rain sensor not kicking in as well tried with manual setting with lever pulled down and lid lifted manually - still does not activate fan.
So kind of a mystery.
Could it be the In and Out switch? if so are they replaceable?
Or could it be the thermostat? same question can I just get that part.
Or is the fan motor pooched?
My front vent was installed originally and the white inside mounting is cracked in the corners - do you know if they honour replacing that part. I would also like to have them change out the screen from the screw type to the snap in type which fits as the rear fan is newer and it has the snap in kind.
Any suggestions on the fan blade issue not turning?
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 07-03-2012, 05:44 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Bad holiday timing
Fantastic is a great company! They usually fix any problem for little more than the price shipping!
I'd start with the simple stuff, bypass/hotwire the direction switch ( a generic replacement can be found at Radio Shack, if not any name brand auto store will surely have one)
If that isn't the problem, move to the thermostat.
If none of this seems to be the problem, try to add 12 v to just the motor to see if it spins, if so, then the board is toast.
Good luck, going to be hot everywhere this week!
Old 07-03-2012, 05:49 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I forgot to mention
I have a few interior trip pieces, These are new, unused in both white and the off white. These trim surrounds are designed just for the AS, as they have a built in radius to match the radius of our roof. The Fan kits you buy at stores come with a flat trim.
Yours for the cost of shipping....
Old 07-03-2012, 07:05 PM   #4
Buckhorn , Ontario
Images: 59
Thanks for the info and offer of your of the trim pieces AtomicNo13.
Since I have no clue how to hot wire - I was thinking of taking the switch from the front one and see if it works the back one if yes then ha it is the switch.
As for the thermostat - they usually are still working if you turn the dial right and you here it click at the temp of the inside coach and this one does.
So if the terminal is the same as the front one then I can check that after dinner and give a progress report.
Where are you located and what would the shipping be - could I pay you via payola? - I am interested in the white one.
Sharon
Old 07-03-2012, 07:10 PM   #5
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Sharon, I am by no means a FF tech but I have been told that most of the time the trouble is with some sort of ground wire there at the fan itself. Look for a wire that seems loose or corroded.
Good luck.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 07-03-2012, 08:02 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Check the plunger where the lid closes on it. Work it up and down several times to wear the corrosion off the contacts, and the fan should start working again. You will need to take the screen out of the fan, and reach up through the opening to work the switch with a small stick or screwdriver, or else climb on the roof to get to it.
Old 07-04-2012, 10:30 AM   #7
Buckhorn , Ontario
Images: 59
Okay Fellas...
Sorry dropped off last night ate late and fell asleep and the fan was too complicated to work on that late.
Soooo I think I have now solved the issue.
As my front fan works fine and they have the same connections thought I would do a process of elimination. Too bad I did not start with the bum component ha So I had the fans apart three times!
I changed out the In and Out switch and the bad fan switch works in the good fan.
Put the good fan switch in the bad fan and it still does not work.
Put the good fan speed dial in the bad fan and it still did not work - fan would not come on.
When I put the bad fan speed dial in the good fan it also did not work meaning lid would open but fan would not come on. But when I put the good fan speed dial in the bad fan lid goes up but fan still would not come on either manual or auto.
So what does that tell me? My guess is...
That the board connection to that speed dial switch is bad? as well with the dial itself being bad? or is it just the board as I know the good fan speed dial works.
Can anyone enlighten me?
Old 07-04-2012, 10:37 AM   #8
Buckhorn , Ontario
Images: 59
Not sure what you mean here OV63 by "plunger" the arm that lifts the lid it works fine nothing obstructing. Lid has no problem going up and down on auto or manual - it is the fan that does not turn on when the lid is raised either auto or manual.
The speed dial if on 0 - fan does not come on - vent mode - but on 1 it should but does not either auto or manual.
Old 07-04-2012, 11:06 AM   #9
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
It is difficult to see the plunger from inside the trailer but easy from on top with the lip up. It is simply and on-off switch which turns off the fan when the lid it closed a certain amount. I had a similar problem with one of my fans and it was a sticky plunger.
Bill
Just my personal opinion
Old 07-04-2012, 11:11 AM   #10
Buckhorn , Ontario
Images: 59
Bill
But that does not explain why the bad fan switch does not work in the good fan - and it does not have a plunger issue. Do you think I might have two things wrong going on with this fan.
I don't know if I can get up on the roof with the ladder I have. Will have to see what the camp may have.
Old 07-04-2012, 11:35 AM   #11
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Open the windows for now and call FF tomorrow. The tech I talked to diagnosed our problems over the phone (would not close automatically, but would open; said it was the circuit board). He sent me a new kit for the cost of shipping (around $15 instead of the $100 for the kit). It'll take about a week to arrive. I don't understand what your problem is, but the tech may figure it out.
Gene
Old 07-04-2012, 11:48 AM   #12
Buckhorn , Ontario
Images: 59
Gene
That's what I'm thinking it is too - the circuit board went bad and then blew the speed dial switch along with it.
Will have to wait till the 6th as they are enjoying their holiday and I believe they are all out doing shows this week too.
My big problem is when the AC is not on I live by the fans - since I have a small trailer the air between the two is "fantastic" ha pun intended. But alas the back vent is always on the out position - as I cook in my trailer and it is great for keeping all the moisture and smells out - but the stink pipe to the bathroom is right beside it - so running only with my front fan will pull that stink in.
Alas your idea about opening windows will be the ticket - will keep the back window open at night instead for now - of course it has to be hotter than you know what out.
Thanks for all your help guys....guess I will have to be patient and wait for Bob Barrett to get back - he is a super nice guy and yep he will tell me what the issue is in a heart beat - bad timing on my part I guess
Old 07-04-2012, 11:51 AM   #13
Master of Universe
Gene's Avatar
You can use the bathroom and shower fans too.
Gene
Old 06-18-2013, 12:10 PM   #14
StagrLee's Avatar
2012 25' FB Eddie Bauer
Wanted to updated this thread with photos. The "plunger" is just above the fan on/off switch. Electrically, the switch and the plunger complete the ground side of the motor circuit. Take the fan shroud screws off, let the fan dangle and spray the plunger with Contact Cleaner and Lubricant (lubricating contact cleaner). If you never had the shroud off, you will likely have to get the silicon off the power wires next to the fan on/off switch.
Part "1D" is the plunger.
Gene
One thing I noticed with the bathroom fans is that it introduces a ton of interference into the TV reception!
Probably a bunch of arching in the brushes of those motors. The Fantastic Vent fan doesn't do that.
ID:	188552   Click image for larger version
"Stagr" Lee
2012-1/2 25' Eddie Bauer
StagrLee is offline   Reply With Quote
