Old 04-30-2010, 05:42 PM   #1
2004 30' Classic
Hillsborough , New Jersey
fantastic vent doesn't work
I have two Fantastic Vents in my 04 classic Airstream. They are great but the one in the bedroom stopped working recently. I called Fantastic Vents and they were excellent in helping me diagnose the problem and they sent me a replacement circuit board for free. I replaced that and the new control switch but it still doesn't work. I have power up to the vent. Anybody have any ideas what could be the problem??
wolf146 is offline   Reply With Quote
Old 04-30-2010, 05:49 PM   #2
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
is the battery in the remote good? If so does it need to be reset? You say you have power... How about the ground?
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 04-30-2010, 05:55 PM   #3
2004 30' Classic
This unit does not have a remote. Which wire would be the ground? there are green, blue, red, black and white wires.
Old 04-30-2010, 05:58 PM   #4
Elkhart , Indiana
Well...???Let me go look in the garage... I have a new in the box one... B R B
Mike
Have a great day!
Old 04-30-2010, 06:01 PM   #5
Elkhart , Indiana
Black is positive.... White is negitive/ground should go from fan to a contact on the trailer skin (at least this is where our goes)
Mike
Have a great day!
Old 04-30-2010, 06:03 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Stoopid suggestion: Check the fuse.
Old 05-01-2010, 02:36 PM   #7
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Green is ground (at least it is supposed to be)
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 05-01-2010, 02:58 PM   #8
2004 30' Classic
fantastic fan
fuse is ok. thanks for your suggestions.
Old 05-01-2010, 03:10 PM   #9
ctdair's Avatar
Same problem here with a 2004. Was going to call Fantastic Vent on Monday. It worked fine when stored for the winter and was intermittent in operation at the last rally. I spun motor after it looked like motor started to turn then stopped , motor is free no binds. Worked all day after that (hand spin with power off and then a restart). Rain Sensor closed the vent during the night and fan would not restart , tried to hand spin again no luck. Left cover open and a hour or so later fan started working. Tried fan today and it is dead again. Havent trouble shot system yet any further than that , I am leaning towards the circuit board myself , was hoping for a diagram from Fantastic Fan.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 05-01-2010, 03:45 PM   #10
2004 30' Classic
You can unplug the rain sensor and see if the fan works. What "stumped" the man I spoke with at Fantastic Vent was that both the fan didn't work and the vent didn't open automatically. I would be ok with just having the fan go, since I can open the vent manually. I would be interested to hear from you about what advice Fantastic Vent will give you.
Old 05-05-2010, 04:20 PM   #11
ctdair's Avatar
Vent always opened fan not running was he issue so I guess a little different from Your problem. I called Fantastic today and was advised to clean the contact of the plunger switch under the cover. It is perfectly obvious once You know it is there to see it. It was a 7/16 wrench to remove and some contact cleaner and now everything works fine.
S/OS #010
Old 05-06-2010, 07:02 AM   #12
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I had this problem once a few years ago and couldn't figure out what the problem was. Turn the unit on then turn the temperature adjustment knob. The knob has a cutoff built in. It's worth a try.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 05-06-2010, 12:18 PM   #13
Baltimore , Maryland
CT hit it on the head... it is the plunger switch. I am almost 99.3% sure of it.
Remove the nut and clean the contacts. It will work perfectly then.
Old 05-07-2010, 04:46 PM   #14
2004 30' Classic
fantastic vent
thanks for your suggestions. I'll try the sugestions. thanks wolf
reverse switch on Fantastic Vent bradk Roof Vents, Skylights & Fans 19 07-12-2006 11:11 PM
Roof work--Fantastic install lundfog Roof Vents, Skylights & Fans 2 06-11-2006 04:27 PM
Fantastic Vent R&SZinser Roof Vents, Skylights & Fans 11 11-30-2005 07:56 AM
Fantastic Vent sticking 74Argosy24MH Roof Vents, Skylights & Fans 37 06-09-2005 05:15 AM
Which Fantastic Vent? uwe Roof Vents, Skylights & Fans 9 08-30-2004 09:37 AM
