Old 05-30-2016, 07:46 PM   #1
2016 25' Flying Cloud
Pennsylvania , Pennsylvania
Fantastic Fix Plunger Switch
There is a molded rectangular plastic part on the inside lid of our fantastic fan that is designed to depress the plunger switch and shut off the fan upon the fan lid closing. However, it appears from factory it simply would not do so, and somewhere along the line somebody put a little plastic/rubber nub on there to extend the molded rectangle piece so as to make contact with the plunger and shut off the fan.
Well, that worked for a bit, but the the rubberized nub simply got pushed out of the way over a very short period of time through use.
I've fixed it for now. I tore that clear plastic nub off there. Then, by backing the plunger out far enough to slide in a hand cut/homemade U shaped washer and then tightening it back down, it raised that plunger far enough that it now is pushed down enough to shut off the fan when the lid closes on top of it.
Name:	plunger switch (2).jpg
majorairhead is offline   Reply With Quote
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Hensley Spring Plunger, Grease fitting spring bar retainer dznf0g Hitches, Couplers & Balls 2 08-29-2012 07:43 PM
Is it a hotdog cooker or potty plunger?!! Becky B. Off Topic Forum 14 11-20-2009 01:16 PM
Is a plunger going to help this? Cos Exterior Restoration Forum 9 11-27-2006 05:58 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
