07-28-2016, 03:16 PM
#21
2000 25' Safari
Davidson County
, NC Highlands County, FL
Originally Posted by Fox2A
I own a 25', '04 International CCD, with forward and aft ceiling fans/vents. The fans are not working and I've checked all of the fuses etc. and the manual info. is not helpful in terms of problem solving. They do not appear to be 'dirty' etc.. Is there a 'trick' to these fans, other than having the vents open at least 3"? Power seems to be getting to the Fans, given their millisecond start, but they don't continue. Thanks in advance for any feedback etc..
Barry
Trout Lake, Wa.
When you say there is "millisecond start" do you mean you hear something activate, or do you see the lid start to raise?
I hear that noise sometimes when the lid up/down switch is in the lid down position. Make sure that switch is in the correct position.
I've also have had the lid get stuck after being closed for an extended period. Pull down on the largest knob then turn it to open the lid manually. Doing this should start the fan if the thermostat is calling for cool.
Remember the fan speed knob has to be on 1, 2, or 3 to make the lid open and the fan turn on automatically.
Alan
07-28-2016, 03:24 PM
#22
2015 27' Flying Cloud
Newberg
, Oregon
Maggie, the first time you take the screen off from the inside, it seems like you are going to break it. But it flexes and eventually comes free. There is a area wth a slightly raised edge that you can start at. I had to take my fan blade off for some reason on our last trip, I can't remember why, but it too was hard to get off after removing it's holding screw. But it all came as described in the users/installation guide. Putting the fan back you have to align it just so so it doesn't rub against the screen. It all came together about the third time I redid it. A step stool helped to reach everything easily.
Mike
Mike
07-28-2016, 03:38 PM
#23
Normal
Thanks, Mike.
I have taken it off once, to clean the blades, but it was an ordeal.
I clean the screen by vacuuming it.
Since the red light is out, and looking at that requires a repair person getting on the roof, I didn't persist with removing the screen.
Maggie
07-28-2016, 03:49 PM
#24
Washington
, Missouri
Mike
Mike
Maggie, I had mine off recently on an educational mission since I was dealing with the seals coming loose.
In case you want to try again, as Mike mentioned, start at raised edge...push the flange portion of the screen in at least an 1/8" inch to release the little tab, then pull down. There are maybe a dozen or so, so work your way around the edge. After you've released 3 or 4 tabs, you can start to pull the down & off.
In the image you can see the tab at the edge of the screen so you will know how far you need to push the edge in to release before pulling down. Also you can see the switch. Down flush is the cutoff and popped up allows the motor to turn on presuming the fan switch is on, the thermostat is on high and there is no moisture on the rain sensor.
Check your instructions if you have them. Depending on vintage you may be able to pull the fan out to access the tab.
Goof luck.
p.s. if you get it working and the screen makes noise, make sure all the tabs are snapped & locked and the flange tight to the housing.
07-28-2016, 05:10 PM
#25
Normal
Thanks, guys.
Maggie
07-29-2016, 10:55 AM
#26
Normal
Fixed!
The problem was a loose wire to the control panel, which Joe at Fireside Camper in Watertown, SD, fixed from the roof at no charge.
http://www.firesidecamper.com/
Maggie
12-21-2017, 04:49 PM
#27
2000 25' Safari
Davidson County
Fantastic Fan. Red light blinking. Lid will not open automatically
I installed a Fantastic Fan in my Excella last winter. It has worked fine until yesterday when I noticed the red light blinking. Now the lid will not raise on its own.
I cannot find an answer on Fantastic Fan website.
The fan works normally after I open it manually. It will run, the thermostat works, the lid will close if I move the switch to the close position. The lid will not raise when I move the switch to the open position.
Has anyone got a suggestion?
add edit:
This fan does not have remote control
Alan
12-21-2017, 06:50 PM
#28
Kensington
, Maryland
Alan, I am by no means the expert. I had a similar problem when camping at Hatteras this year. After we got home and the AS dried out the fans started working normally. There is a problem with the design IMHO. You can try cleaning the sensor itself. I'm probably going to eliminate the sensor completely.
BTW - I did call the tech. support who swore on a stack of bibles that there is not a problem with these fans. Google says otherwise
add edit:
12-22-2017, 06:55 AM
#29
2000 25' Safari
Davidson County
I appreciate the response!
It was a high humidity day in FL yesterday and it's rained most of the night. Maybe dampness was/is the problem.
When it stops raining I'll get on top and clean the sensor.
Alan
12-22-2017, 11:54 AM
#30
2000 25' Safari
Davidson County
I climbed up on top and cleaned the rain sensor with a damp paper towel (though nothing was visible on it). While I was up there I noticed the ground wire from the fan motor does not run back inside the fan housing. It has a ring terminal eyelet connected to the end of the ground wire. That ring terminal eyelet is beneath the nut that holds the plunger switch. I gave that wire a little nudge that tightened the nut a bit. Now the light is not blinking and the fan lid is opening and closing normally. The red light is not blinking.
I assume the issue was either loose ground or a dirty rain sensor , or a combination of both.
Alan
12-22-2017, 01:06 PM
#31
Kensington
, Maryland
Nice work brother
The issue with the rain sensor being overly sensitive to humidity might still be a issue. Here, I found a thread which may explain my statement:
http://www.airforums.com/forums/f455...de-173222.html
This is my plan to cut the rain sensor wires:
http://www.irv2.com/forums/f103/fant...de-310540.html
12-22-2017, 02:51 PM
#32
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Yup, if the red light is blinking on your FF, the moisture sensor in the fan thinks it has been rained on and it won't re-open with the switch until the sensor dries out. A bad connection might possibly cause the same effect.
We had this happen several times during our 3 month trip, much of which was in very humid areas, and "learned by doing." The real comedy began early in our trip when I realized I had wired the fan backwards, so that whenever it got wet, the unit automatically opened the vent as far as possible and held it that way until I cranked it shut by hand and considered what I might have done wrong to cause such a thing.
12-22-2017, 04:42 PM
#33
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
I've never observed any blinking lights on our fans but sometimes (actually a lot of times) late at night ours will continually open and close. I've cleaned the sensor but the only cause I can come up with is evening dampness. I end up closing or opening it and shutting it off. Now, that's come back to bite me at least one time with a late night rain storm. So leaving it open and off is probably not a good idea
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
12-22-2017, 04:51 PM
#34
Green Cove Springs
Ah, I upgraded both of our FF units so the fans are reversible. That’s how we got the red light that blinks when the sensor is damp.
12-22-2017, 05:14 PM
#35
2017 25' International
Niagara-on-the-Lake
, ON Canada
Originally Posted by polarlyse
... but sometimes (actually a lot of times) late at night ours will continually open and close. I've cleaned the sensor but the only cause I can come up with is evening dampness. ...
If our fan closes due to rain it doesn’t re-open automatically, however the thermostat control does open and close the fan cover automatically.
Ray B.
12-22-2017, 06:08 PM
#36
2000 25' Safari
Davidson County
Only those FFs built after 2014 have the red light.
I put an Ultra Breeze cover on the fan over the bed on both of my trailers. It fits the fan lid perfectly since it is made by FF. With that done I can leave the fan lid open rain or shine, traveling or parked. Still have to clean the sensor about once per year.
Alan
12-22-2017, 06:21 PM
#37
2000 25' Safari
Davidson County
I just looked at the first few post in the link you provided.
I thought about cutting the wires too, but I do not want to loose that rain sensor function during those times I leave the fan running while I'm not there.
While I was looking at the FF website today I noticed some models have a rain sensor override switch. It appears to be a simple on/off switch. One could add a toggle switch in the fan housing that would act as a disconnect for the rain sensor. Or, maybe FF would provide one if requested?
Alan
12-22-2017, 06:28 PM
#38
Kensington
, Maryland
If you talk to the techs. at FF let me know how that goes.
I'm also liking the idea of adding: Ultra Breeze cover and cutting the wires so I can leave it open and not worry about rain...as much
Someone mentioned a upgrade that includes a reverse flow function AND a new rain sensor? If that rain sensor is improved I'd be game. Reverse air flow would be excellent.
FWIIW Those rain covers are on sale at Camping World.
Fan-tastic Ultrabreeze Vent Cover - White
#58894
12-22-2017, 06:35 PM
#39
2000 25' Safari
Davidson County
I have 4 FFs, 2 on each of my trailers. All of them have a reverse switch that changes direction of air flow. Three of them are Model 3350 I think. The one in the rear of the Excella was the same model, but Airstream customized by adding a wall mounted thermostat.
I did notice an upgrade kit that had a rain sensor and switch. I think it is an add on of existing technology for the less expensive models that came without, nothing new.
Alan
