Old 10-12-2007, 02:45 PM   #1
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
Fantastic Fan quit - what should I check
Hi
my 2 weeks old fantastic fan quit few minutes ago.
It doesn't spin anymore. The opening/closing works.
The motor started to slow down then nothing...
any idea... is it dead?
thanks in advance.
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 10-12-2007, 03:01 PM   #2
millvalleyca's Avatar
2008 27' International CCD FB
Mill Valley , California
that happened to our new unit....check the manual knob and make sure it's pushed all the way up...also check the thermostat
millvalleyca is offline   Reply With Quote
Old 10-12-2007, 03:18 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Same thing here...
Turned out to be operator error but I STILL think there are one too many controls on the darned thing. Don't forget that there is an ON/OFF toggle switch as well as a fan speed switch which has off as one of the speeds.
If you have the fan set on AUTO and the vent won't open, sometimes the gasket gets sticky. Generally you can pull the lever to MANUAL and gently crank back and forth until the gasket loosens up. Lube it with something designed for neophrene. Then with the ON/OFF switch ON and the speed switch on 1, 2, or 3 the fan will operate when the vent is open.
If none of that works, call the Fantastic Fan people and they'll walk you through the process of checking everything out, and send you replacement parts (free) if necessary. Nice people to deal with.
Paula Ford
Old 10-12-2007, 05:27 PM   #4
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
the vent open/close perfect, the thermostat is on position to allow the fan to spin.
But as I said it was spinning then it slowed down and did run for a while then it stopped...
And now nada...
TAC# : QC-1
my blog
Old 10-12-2007, 06:04 PM   #5
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Fantastic has fantastic customer support. Give em a call, I'm sure they will put you right.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 10-12-2007, 06:25 PM   #6
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
I will but it's too late now... and tomorrow it's saturday... and I like my AS even with a dead fantastic fan...
TAC# : QC-1
my blog
Fantastic fan altamont 2007 Safari SE 12 01-23-2007 09:06 PM
Fantastic Fan Devoman Roof Vents, Skylights & Fans 35 09-19-2005 07:39 PM
Fantastic Fan # 2 David Hall Roof Vents, Skylights & Fans 20 02-15-2004 09:15 PM
Fantastic Fan mopar7 2003 Safari 14 10-31-2003 06:21 PM
Fantastic Fan jalewis Roof Vents, Skylights & Fans 1 09-29-2003 06:16 AM
