Old 10-21-2010, 11:10 AM   #15
crowldawg's Avatar
1966 20' Globetrotter
Orient , New York
That was the first thing I did .
crowldawg is offline   Reply With Quote
Old 10-29-2010, 06:47 AM   #16
crowldawg's Avatar
Orient , New York
Got a new 3 way switch from Fan-Tastic .Installed yesterday and the fan is back in business. Thank you, everyone .Thank You ,Fan-Tastic
Old 10-29-2010, 09:07 PM   #17
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Yep, their customer service is great. I just got around to installing my replacement interior vent shrouds. The 1998 originals were designed for a flat ceiling and eventually cracked. The new shroud is curved but when I put it in it didn't match the curve of the ceiling....After further inspection, I found 2 pieces of 2x4 jammed into the ceiling to flatten the curve to the point where the original flat shroud would look decent. I removed the 2x4s and pushed up on the ceiling and the aluminum popped back into round and the new shrouds fit perfectly.
4RXLA is offline   Reply With Quote
Old 10-29-2010, 11:43 PM   #18
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Originally Posted by cclarkego View Post
I'll have to wait for the repair guy next week when he works on my refrigerator. I don't think I have the right gizmo. What do I need to check it?
Carol
Carol, get a semi quality "volt-ohm meter". Home Depot, Lowes, Radio Shack should be able to help you. Don't get the cheapest, but you don't need the top of the line. Digital is good for most everything. I bet other's will point you in what you need to know with your full timing. You'll be surprised how often you'll be using it, like checking your TV plug or battery or light switches or even checking continuity in a faulty fuse. Then practice with it, AC hot is usually the small slot in the AC plug and a black wire, AC neutral is usually the bigger slot in the AC plug and a white wire and shouldn't have very many volts on it to aluminum, AC ground is usually green and the odd round slot in the AC plug.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 10-30-2010, 02:06 PM   #19
2008 23' International CCD
mountain home , Arkansas
fantastic fan
I have called Fantastic fan many times and they have sent new parts free no questions asked...they are a Great company and I would recommend that you give them a call
beercan is offline   Reply With Quote
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
Fantastic Fan problem davidz71 Roof Vents, Skylights & Fans 10 02-07-2007 04:47 PM
Fantastic fan altamont 2007 Safari SE 12 01-23-2007 09:06 PM
Fantastic Fan Devoman Roof Vents, Skylights & Fans 35 09-19-2005 07:39 PM
