03-26-2016, 09:32 AM
#21
1992 32' Excella
Elma
You will need to confirm the measurements from your old unit. I pulled mine out once I determined there was a great chance of getting a new Window Torque Center Mount Operator.
Having this shroud around the fan it does move quite a bit of air, and I did not want to change out my lights
Here is the link to the unit I needed. http://www.dkhardware.com/product-13...re-socket.html
[ATTACH][ATTACH] [/ATTACH][/ATTACH]
If you don't have the time to do it right the first time where you gona find the time to do it a second time.
03-26-2016, 09:55 AM
#22
1992 32' Excella
Elma
OH and BTW. Vintage Trailers has replacement Lexan Lid for Radiused Corner Roof Vents. Little spendy But Still less expensive than a decent fan replacement not to mention the afterthought lighting issue.
http://www.vintagetrailersupply.com/...-p/vts-852.htm:
03-26-2016, 01:31 PM
#23
1998 30' Excella 1000
Livingston
One can significantly increase the life span of the original plastic lid by sanding and painting it. Mine shows no further weathering in the three years since I did it. You lose a little natural light, but not much. And many have a skylight adjacent anyway.
03-26-2016, 09:47 PM
#24
1992 32' Excella
Elma
Good Point. I got to looking at both of mine today and looking at how little light I think they will let in even with new ones, I would do just fine with a coat of Silver Spray paint. That would save me 150.00.
03-27-2016, 05:08 PM
#25
Livingston
Exactly what I did.
A tip. Start with coarse sand paper. You'll be amazed at how white the plastic was. About an hour to take it off, sand it, paint it. Less than $5. And I think the silver finish looks better than the original white. Priceless.
04-01-2016, 07:10 PM
#26
1999 34' Excella
Cinnaminson
, New Jersey
Originally Posted by Dwight
Hey Dwight I assume that was originally the fan/light combo? Great idea to add lights to the side. I just ordered a new MaxxFan Deluxe to replace and I and trying to find a way to keep the lights. Honestly the old one wasn't that bright anyway and 2 new thin lights would be awesome!
04-01-2016, 07:23 PM
#27
1999 34' Excella
Joshua
You are correct!! I just wanted to match the existing lights.
History doesn't repeat itself, people do!
04-01-2016, 07:33 PM
#28
2000 25' Safari
Davidson County
, NC Highlands County, FL
Dwight,
Your solution is the best I've seen so far. It looks good!
Where did you find those light fixtures. Those are exactly what I have.
04-01-2016, 07:52 PM
#29
1999 34' Excella
Joshua
I'm not sure....that was 15 years ago! I've got to go to the trailer tomorrow so I'll check.
04-02-2016, 05:56 AM
#30
1999 34' Excella
Cinnaminson
, New Jersey
I agree! best solution I've seen yet. Looks like it came that way. Thanks for posting the pic I know what I'm doing now!
Btw you can buy the thin lites on Amazon. Just find the one that matches the others you already have.
04-02-2016, 08:51 AM
#31
2000 25' Safari
Davidson County
The light shown in the web link below looks like the existing lights in my Excella. I thought the lights in mine were surface mounted. The description of this one says it is recessed.
http://www.amazon.com/Thin-Lite-736-...2&sr=8-2-spell
Dwight, Did you cut into the ceiling to mount your lights?
The photo below is of the fixtures in my 99 Excella. Can anyone tell me if your lights like these are recessed?
04-02-2016, 11:42 AM
#32
1999 34' Excella
Cinnaminson
, New Jersey
Fantastic Fan, over head lighting ?
I have a 99-34' that is what mine look like as well. They are recessed. Pull the lens covering the bulbs and you can see its definitely recessed. You will need to do a little surgery but the end results are worth it.
04-02-2016, 11:51 AM
#33
1999 34' Excella
Joshua
Yes, you'll need to cut out the ceiling since they are recessed fixtures
04-02-2016, 04:43 PM
#34
2000 25' Safari
Davidson County
Thanks!
I'm not cutting the ceiling, so I guess I'm back to thinking about it ;-)
My Excella is in storage until October, so I have a while.
04-02-2016, 10:23 PM
#35
1999 34' Excella
Cinnaminson
, New Jersey
You don't have to cut the ceiling. If you are not comfortable with that you could use surface mount thin lites. You would still have to at least drill a
Hole for wires and a few screws to
Mount it.
Dwight cut in recessed lights to match the existing. But you don't have to.
04-03-2016, 08:39 AM
#36
2000 25' Safari
Davidson County
Drilling a hole for the wire is my plan. A thin surface light might be the answer.
I'm trying to find a surface mounted light, or two, that will not look out of place and will adequately illuminate the two tables beneath. We use those tables constantly, for dominos, board games, and cards. We've had 6 people at times.
I'll try to find one of those matching lights locally, to see how deep they are before purchasing. Or, maybe there is a thin LED puck fixture that will do the job. I'll continue to search. I'm only a few miles from LED4RV and ODM , so I can check out what they have in the store.
04-03-2016, 10:27 PM
#37
1972 31' Sovereign
felton
after removing light fixture and replacing original fan with a Fantasic .. I wired up this LED light, it works well kinda bright, not good for low ambient lighting
http://www.amazon.com/Dream-Lighting...SB8A3266R8CWAF
04-03-2016, 11:45 PM
#38
2000 25' Safari
Davidson County
Originally Posted by nickclifford
I was just looking at that fixture. Do you have any photos of the install?
04-04-2016, 04:15 AM
#39
1980 31' Excella II
1973 31' Sovereign
Noonan
, New Brunswick
I have purchased 4 fantastic vents for my trailer. I plan on utilizing the stick on led tape lights with a track from https://www.1000bulbs.com/category/l...nnel-profiles/ . Get the white ones and does a really nice job. Or you could do color and do a light show.
WBCCI #6722
Ham Radio VE9NKD
05-21-2017, 09:03 PM
#40
2000 25' Safari
Davidson County
I finally got around to fixing the problem this past winter, but I guess I forgot to post about it. (or at least I could not find a post after I was asked what I did)
I never was able to find a lift mechanism to replace the broken one. I decided to get rid of the old original fan/light and replace it with a Fantastic. The new fan covered the old footprint of the existing, so the vinyl ceiling looks like it always has. Nothing ugly from the old light's mounting is showing around the perimeter.
I added two surface mounted lights that matched those above the sofa. I changed out the bulbs to warm white LED. The 4 LED light bulbs seem to be slightly dimmer than the old daylight colored fluorescent bulbs. But, that might be the color difference, not actually dimness.
I'm really happy with the results, especially the air flow and the additional daylight coming.
Alan
