Old 10-22-2015, 07:56 PM   #1
2016 25' Flying Cloud
Nanoose Bay , British Columbia
Fantastic fan lid has stopped working
Our AS is brand new - built in June 2015. It has two Fantastic Fans. On the rear fan when the vent lid reached full open (or full shut) the motor would continue to whir away and would not stop automatically. If I touched the motor's knob it added a bit of resistance and it stopped. Then quickly it started only opening part way and stopping there then it wouldn't open at all - the motor just whirred away but the lid did not move. So we ceased using it and relied on the other fan which works fine.
I know from reading other threads that the lid motor is supposed to stop when the lid reaches full open or full closed or the lid encounters an obstacle e.g. a vent hood that is too low (I don't yet have vent hoods).
The fan will spin but the lid won't go up. The fuse is intact.
Any one know what's wrong? Perhaps the motor's lid lift gears were defective? Is this going to need a replacement of the whole unit or will it be possible just to replace the motor box and gearing. I know this will be a warranty repair but since I'm going to have to get a local dealer do it and submit my receipts to my AS dealer for warranty reimbursement I'd like to get a sense of what kind of repair they are going to have to do.
Gary Nijman
2016 Flying Cloud 25 FB Twin
2018 GMC 3500 Denali Duramax
gnijman is offline   Reply With Quote
Old 10-22-2015, 08:14 PM   #2
2015 27' FB International
Newmarket , Ontario
Subscribed - I have the same out of control whirling on one of my fantastic fans. Will have the dealer check it out in two weeks.
Mike
Newmarketca is offline   Reply With Quote
Old 10-22-2015, 09:24 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Sounds like a stripped lift gear....happened to mine recently.
CRH is offline   Reply With Quote
Old 10-22-2015, 10:20 PM   #4
2013 31' Classic
Simpsonville , South Carolina
Or perhaps the knob for opening it manually is not fully engaged for automatic operation. Have you tried pushing it up until it "locks" in place? If not fully engaged it can act as you describe. It needs to be pulled down fully for manual operation. Anything in between will allow it to act as if the gears are stripped.
Have you tried opening it manually?
ArlinV is offline   Reply With Quote
Old 10-23-2015, 11:17 AM   #5
2015 25' FB Flying Cloud
Huntley , Illinois
we had a problem with ours 2015 FC. we called tech support at fantastic fan. very helpful. not related to your issues but they have changed the operation of the fan. it will jot reopen after it closes due to rain. they changed this to prevent the batteries use when boobdocking. like i said notcrelated to sour problem. you may want to call tech support before the dealer visit. i had to let the dealer know of the changes cthey were not aware
cegardner is offline   Reply With Quote
Old 10-23-2015, 11:29 AM   #6
aftermath's Avatar
Spokane , Washington
"boobdocking"?
Sounds like fun.
aftermath is offline   Reply With Quote
Old 10-23-2015, 11:42 AM   #7
mesquite , Texas
2015 27ft. international signature. fron fan has same problem
wont open --- will open ---shuts and opens on its own . does what it wants when it wants.
don't really know if the knob pulls down or not . tried it but didn't want to break it so don't know if it does or not. seems to be the same problem as what everyone else is having.
moxie t. moto is offline   Reply With Quote
Old 10-23-2015, 11:56 AM   #8
dznf0g's Avatar
Oswego , Illinois
Originally Posted by aftermath View Post
"boobdocking"?
Sounds like fun.
ooops
-Rich-
Old 10-23-2015, 01:22 PM   #9
2015 23' FB Flying Cloud
Redmond , Washington
Yeah, ya gotta love spell chicking!
D2
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 10-23-2015, 01:49 PM   #10
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Call Atwood, they own Fantastic vents, and should be able to resolve these problems pretty quickly.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 10-23-2015, 01:55 PM   #11
1985 32' Excella
Harrisburg , Ohio
Remove the fan motor. There is a part number on the fan motor. Google that part number and you will be directed to a link that has the proper part(s) you need. Cheap and simple.
Rossco57 is offline   Reply With Quote
Old 10-23-2015, 02:32 PM   #12
The one knob does not pull out or push in. It's fixed. On both units. The knob spins around when the motor runs in its futile attempt to open the lid. I will call manufacturer support.
Gary Nijman
Old 10-23-2015, 03:21 PM   #13
2014 23' FB Flying Cloud
Mill Valley , Left Coast
I tried pulling down on the control knob on both my fans and all it did was strip the attachment screws and pull the whole motor unit down. repaired with epoxy but I don't think my fans have a manual door opening setting.
14 23' FB FC.
J.B.
jbxx is offline   Reply With Quote
Old 10-23-2015, 04:41 PM   #14
2016 30' Classic
Santa Rosa , California
Older vs newer fans
I read elsewhere that older FF required a pull down to engage manual mode. Newer models dont require this.
phann is offline   Reply With Quote
Repair or replace gears for Fantastic Fan lid? blickcd Roof Vents, Skylights & Fans 2 09-17-2014 02:15 PM
troubleshooting fantastic fan that stopped running bonginator Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-05-2014 04:42 PM
Dash Air Fan, Power window and Power Seat Stopped working alvinator Land Yacht/Legacy Motorhomes 3 07-13-2014 10:22 AM
Range Hood Fan and Light Stopped Working No. 13 General Repair Forum 21 06-05-2013 07:27 PM
Dometic has stopped working on AC? Pacerized Refrigerators 6 04-21-2009 08:28 PM
