Old 10-22-2018, 04:56 PM   #1
1961 22' Safari
Fort Lauderdale , Florida
Fantastic Fan Installation - 1961 Safari
I have a 1961 Safari and I am looking to replace the 14X14 vent with a fantastic fan. Vintage Trailer Supply has an option for a flat garnish or curved garnish, I was thinking I would need the curved one, but I am not sure. Has anyone installed one? Also, I don't have 12V electric, I have standard 110, will this work for the fantastic fan or would I have to convert my power before I could install?
Bobbyo954 is offline   Reply With Quote
Old 10-22-2018, 06:03 PM   #2
DFlores's Avatar
1968 22' Safari
Buda , Texas
Yes, get the curved, it may help because I installed the flat on my 66 and am still fighting leaks because the outside is not curved
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 10-22-2018, 07:00 PM   #3
Central , Mississippi
Your 61 should be wired for 12V even if it's not currently being used. The battery box was attached to the outside front shell just below the window, it was a goofy sized battery and is still available. The wires should be inside the box. If you don't want/need 12v for your use, you could add a 12v power supply just to run the fan. The should be a 12v circuit somewhere you can tie onto, perhaps under the pantry or in a cabinet. This vintage only had one long daisy chained circuit with no fuse block so any point is a reasonable tie in.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-22-2018, 11:42 PM   #4
1961 22' Safari
12v
That is good to hear. The vent has some old wiring there, so there was probably a fan there at some time . There a few small square patches on the front where the sofa was, maybe there is access to the 12V wires there, could I add batteries to the front and connect them? I will do some searching tomorrow!
Thanks Bobby
Old 10-23-2018, 07:39 AM   #5
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
Curved vs flat garnish
Go ahead and get the curved garnish. You can trim it with an exacto knife if too curved.
VintageRV is offline   Reply With Quote
Old 10-23-2018, 10:15 PM   #6
adobehome's Avatar
1962 19' Globetrotter
New River , Arizona
The curved was perfect to finish inside if my 2 Fantastic Vents in my 1962 GT. Plenty of 12v lines in the roof to make connections. Eazy breezy!
Judy & Bill
'62 GT
adobehome is offline   Reply With Quote
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
MaxxAir II Vent Cover over Fantastic Fan successful installation longdog Roof Vents, Skylights & Fans 2 12-02-2009 07:01 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
Fantastic fan installation tyndalelady Roof Vents, Skylights & Fans 8 04-30-2006 08:56 PM
Installation of fantastic Fan David Hall Roof Vents, Skylights & Fans 8 01-19-2004 05:18 PM
