Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 03-02-2004, 07:47 PM   #1
Mike B
Mike B's Avatar
Profile:  1977 23' Safari
1976 31' Sovereign
Robbins , California
Fantastic fan install questions
Hi All,
For those of you who have done it, do you use the gasket material betwen the flange and roof or do just bed it in real good with Vulkum or both Vulkum and the gasket? Are rivets or the screws the the best way to attach the flange? I have read all the warnings about watching for the wires when trimming the hole but is there any thing else I should know?
Thanks for the help
Mike B
Mike B is offline   Reply With Quote
Old 03-02-2004, 09:59 PM   #2
j54mark
Profile:
I dispensed with the gasket on mine, used only Vulkem. I started to use stainless screws, but was not at all comfortable having sharp, pointy objects in amongst the main wiring bundle, so I went with rivets. I Vulkemed the rivets as well.
What else should you know? The first time you are on the roof with the new vent, place it next to the opening EXACTLY in the position in which you wish to install it - i.e. with the hinge to the front. This is so that when the opening is cleared, and everything is ready, you can drop it into place with exactly the correct orientation. Doing this saves considerable embarrassment when, having Vulkemed and riveted the unit into place, you open it for the first time - sideways! With an audience. Your wife.
Or so I would suppose...
Mark
Old 03-02-2004, 10:10 PM   #3
tin can luv
tin can luv's Avatar
Profile:  1968 22' Safari
1976 27' Overlander
Newport , Washington
Images: 82
since I will probably be installing soon, I have printed this recomendation out. I am nervous about our first rally, and would hate to install it sideways, and realize this in front of all the other A/S folks...LOL
Ron
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
tin can luv is offline   Reply With Quote
Old 03-03-2004, 02:02 PM   #4
Scott
Profile:
Re: Fantastic fan install questions
Originally posted by Mike B
Hi All,
Thanks for the help
Mike B
Hi Mike,
Many of the manufacturers of RV's that install Fantastics don't use the gasket. They just embed the flange into their favorite caulk. I have some installation pictures made by various Airstreamers and others on my website. The main concern when fastening the Fantastic is to work out from the center crown to the side edges. One screw/rivet at a time alternating side to side toward the side edge. Then screw/ rivet the side edge flanges. Various Installations
My recommendation for Airstreamers is to use what is called a high profile base, more of the vent sticks out on the roof and less knob protrudes into the headroom. (Less head scraping)
Scott
75 GMC PB
http://members.aol.com/fantasticvent
Scott is offline   Reply With Quote
Old 03-03-2004, 03:16 PM   #5
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
you know, this is on my list of "someday" projects for the trailer, but I'm wondering: what to do about losing the light fixture??? those great photo essays on installation...both author's said that they opted to just go without. I'm thinking that there oughta be a light fixture there of some sort. especially if you do 2 vents, like some folks have on the new models. anyone ever done this? what did you use for a retrofit light?
Old 03-03-2004, 03:58 PM   #6
Scott
Profile:
Hi Chuck,
A couple years ago someone sent me pictures of their Airstream vent with like 3 bulbs on each side. I tried very hard to figure out away to adapt the Fantastic for him with using the the lights and trim. The problem as I remember was the location of the lift handle in the middle on the old and with Fantastics being on the side. Most who have responed to me about the light/vent situation have put flourescent fixtures close to their Fantastics.
Scott
75 GMC PB
Old 03-03-2004, 07:03 PM   #7
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
If you do not mind cutting into the interior skin you can even get recessed mount fluorescent lights. This gives you a low profile solution. The new models have all of the lights recessed, either fluorescent or halogen.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
