Old 10-27-2009, 03:39 PM   #15
Gotta agree with Jordan, I think by far the easiest solution is to buy a converter/charger. This will effectively "bridge" your 110VAC and 12VDC systems so that you can run all the 12V lights/fans off shore power when you want to, or off the battery(ies) when not connected to shore power. It will also charge your batteries when connected to shore power.
Edit: (Heh, just read through Rick's post and realized I'm giving the answer that he already knows and doesn't want to see again-- sorry, my friend! )
Old 10-28-2009, 01:35 PM   #16
1963 19' Globetrotter
Moline , Illinois
Going intellipower
After looking at everything , I am going to install a 45amp converter. However I can not find an installation diagram. I already have an outlet to plug it into so can I just then connect the DC side to the battery and then power is supplied through the battery and to the existing wiring? That would make this very simple.
63air is offline   Reply With Quote
Fantastic Fan Install Buttercup Roof Vents, Skylights & Fans 43 10-05-2015 09:46 AM
Fantastic Fan install question Sovereign86 Roof Vents, Skylights & Fans 6 02-17-2009 07:16 AM
fantastic fan install brandok Roof Vents, Skylights & Fans 12 08-14-2007 07:03 AM
Fantastic Fan Install Help Coffeebean Roof Vents, Skylights & Fans 29 01-26-2005 10:18 AM
Fantastic fan install questions Mike B Roof Vents, Skylights & Fans 6 03-03-2004 06:03 PM
