Old 06-04-2010, 05:41 AM   #1
my1ststream's Avatar
1963 24' Tradewind
St Louis , Missouri
fantastic fan install for '63 city/batt system.
Don't mean to be selfish, here. But I am starting to research the old fan replacement to a fantastic fan upgrade. And I want one.
Where do I put the transformer to run it off of city power?
The connections for city/battery power can easily be made, and it will be a quick fix if I just need battery power. I simply have to figure out either a new location for the existing transformer, or simply wire a fulltime 12 volt converted power source from the electric panel.
You guys with Univolt have it made.....
my1ststream is offline   Reply With Quote
Old 06-04-2010, 05:50 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Why not do what we did, and install a converter?
It'll keep the battery charged, and power the Fantastic vent. I mounted ours in a cabinet next to the battery compartment, and simply plugged it into an outlet when needed.
Old 06-04-2010, 10:28 PM   #3
1963 19' Globetrotter
Moline , Illinois
I was faced with this issue and took the advice of Overlander63. I Installed a converter ( Intellipower 45 ) at the same time I put in the new Fantastic fan . Really makes charging and power issues very simple so I also got to put in the stereo I had been wanting.
63air is offline   Reply With Quote
Old 06-04-2010, 10:39 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Good point about the stereo. the Inteli-Powers supply a very clean 12 volts for your electronics.
Vaughan
A Few Notes on Fantastic Fan Install Pick Roof Vents, Skylights & Fans 11 11-09-2015 09:10 AM
Fantastic Fan Install Buttercup Roof Vents, Skylights & Fans 43 10-05-2015 09:46 AM
fantastic fan install version two Frank's Trailer Works Roof Vents, Skylights & Fans 1 11-23-2007 06:01 AM
fantastic fan install brandok Roof Vents, Skylights & Fans 12 08-14-2007 07:03 AM
Fantastic Fan Install Help Coffeebean Roof Vents, Skylights & Fans 29 01-26-2005 10:18 AM
