Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 03-01-2007, 09:52 PM   #1
brandok
Profile:  1967 26' Overlander
ventura , California
fantastic fan install
hey should i use screws/pop rivets/or olimpic rivets to attach it to the roof thanks for all the help
brandok is offline   Reply With Quote
Old 03-01-2007, 09:57 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
We had "the Airstream pros" install ours at International in Salem last year. They used screws.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
InsideOut is online now   Reply With Quote
Old 03-01-2007, 11:08 PM   #3
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
screws. see here....
http://www.airforums.com/forum...ent-23318.html
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Zeppelinium is online now   Reply With Quote
Old 03-02-2007, 05:31 AM   #4
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
I used the factory screws that came with the component. Vulkem for the sealer. Pretty simple install, Good Luck
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is online now   Reply With Quote
Old 03-02-2007, 06:24 AM   #5
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
It's unanimous........
Screws work best and they even give them to you in the package. I used stainless ones when I replaced the FF with a Maxx-Air fan and added a second in the dead vent. Don't be stingy with the sealant (I used SikaFlex) and run a nice bead or two to bed the unit on to before setting it in to place. Then cover all of the screws and the outer seam where it joins the roof.
I sure don't want to be the person whe tries to remove mine .
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 03-02-2007, 06:32 AM   #6
balrgn
balrgn's Avatar
Images: 74
Sorry, forgot to post this.
Power_Vent
Member of VAC
www.balrgn.com
Old 03-02-2007, 07:34 PM   #7
brandok
thanks everyone i will put my two on this weekend. i will take some pics
Old 03-03-2007, 08:04 PM   #8
crestonrv
crestonrv's Avatar
Profile:  1948 16' Wee Wind
1981 31' Excella Limited
2007 19' Bambi
crossville , Tennessee
it's an airstream use oly.rivets and vulkem under flange wipe off excess vulkem with rag and mineral spirits then spray with clear poly urethane. screws will start you on a slippery slope though i have noticed jackson cen. is using a lot more nowdays. how are existing vents attached? screws are a lot quicker & easier.
crestonrv is offline   Reply With Quote
Old 08-13-2007, 11:20 PM   #9
Airstream 65
Airstream 65's Avatar
Profile:  1965 26' Overlander
Winnipeg , Manitoba
We're going to try and install my two new fans tomorrow. So what's the final verdict - screws or rivets?
Airstream 65 is offline   Reply With Quote
Old 08-13-2007, 11:34 PM   #10
lewster
Commercial Vendor
lewster's Avatar
SCREWS! AND LOTS OF SEALANT...........
AIR # 10325
Old 08-13-2007, 11:41 PM   #11
Bradjun1
Bradjun1's Avatar
Profile:  1999 34' Limited
1962 19' Globetrotter
Northern , Minnesota
Use the screws provided and plenty of vulkum. It's an easy job
Bradjun1 is offline   Reply With Quote
Old 08-14-2007, 06:25 AM   #12
overlander63
Rivet Masher
Profile:  1974 31' Sovereign
Southern , California
Images: 42
Just be sure to wear clothes that you are not fond of. When I was done using Vulkem, I was faced with the choice of washing them in 20 gallons of mineral spirits, or tossing them. I hear the garbage men are still trying to get my clothes unstuck from inside their truck.
Important safety tip: Battery acid + baking soda= volcano...
AIR#2611
Old 08-14-2007, 08:03 AM   #13
jzelle
jzelle's Avatar
Profile:  2006 28' Safari SE
Halifax , Nova Scotia, CANADA
I hope that Airstream's workmanship in your trailer is better than it was in mine.I installed a Fantastic fan last week, and when I had removed the old vent I found that the cutouts in the roof and ceiling were off-set by 3/4 of an inch.
If you bought the "high profile" version you may also find that the mounting flange screwhole locations don't match the original.
Good luck I hope you don't find too many surprises.
John
If you need to turn on your air conditioner,you've gone too far south!
2006 Safari SE 28W/LS,
2006 Silverado 2500HD/LT EC SB 4x4 Duramax/Allison,
Hensley Arrow , Honda EU2000i (propane),
160W Solar, 400W sinewave inverter,
3-stage smart charger, Xantrex battery monitor,
Sirius satelite radio
jzelle is offline   Reply With Quote
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 07:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 06:35 PM
A Few Notes on Fantastic Fan Install Pick Roof Vents, Skylights & Fans 10 06-24-2003 06:26 AM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 11:44 PM
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 19 06-23-2002 10:07 AM
