Old 09-21-2013, 02:48 PM   #1
2005 19' International CCD
Belmont , California
Fantastic fan does not work in reverse
I have 2006 Bambi with the Fantastic fan with thermostat and reverse rocker switch. No matter what I try the fan always spins the same way and only does exhaust direction. The manual says put the rocker in the neutral center position but it will only rocker one side to the other. Some way to test if this rocker is bad? I assume the rocker just reverses the polarity so the fan goes the other way? Any suggestions would be appreciated
djpierce is offline   Reply With Quote
Old 09-21-2013, 03:11 PM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Unless it has been modified by someone after it left the factory the fan will only blow out.
Al - K4GLU is offline   Reply With Quote
Old 09-21-2013, 03:16 PM   #3
So why does the manual discuss the reverse option and I do have the rocker switch installed as described in the manual?
Old 09-21-2013, 03:35 PM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
The manual covers many models of the fans. There are two rocker switches on many Fantastic fans. The reversing switch has a center-off position. The switch you see is the on-off switch. Airstream, since about 2004, only installs blow-out fans. I got a kit from Fantastic to install the in-out switch on my front fan. My rear fan still blows out only. With both fans on, I can provide an airflow through the trailer for my cats without opening windows.
You can probably get a kit from Fantastic like I did. Not too hard to install. Make sure you have the fan model in hand when you call them.
John W. Irwin
WBCCI #9632
Old 09-21-2013, 04:05 PM   #5
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
To get a fan to reverse direction, you can unscrew the plate on the inside to get access to the wiring. Trace the wires from the motor and see where they are attached and reverse them—one was too short, so I had to lengthen it. I did this on the rear fan on ours since we have two. It now only blows in and this allows air to move from rear to front.
If you want the fan to blow either way, you have to get a switch that can do that and rewire the switch. Check with Fantastic Fan about that.
I did not want to reverse the front one because it is close to the bathroom vent and might suck bad odors inside. So, if your fan is close to the vent, it should only blow out.
Gene
Gene
Old 09-21-2013, 05:45 PM   #6
Thanks to all. I will see about a switch. What is really odd is there are two rocker switches. One clearly turns the fan on/off..
The other rocker switch just has little icons showing open or blocked -I think. But this switch does not do anything. I guess it is time to pull it out to determine how it is wired.
Old 09-21-2013, 05:55 PM   #7
Master of Universe
Gene's Avatar
If you have a problem with a Fantastic Fan and it is out of warranty, they are pretty good about sending you replacement parts for the cost of shipping. Call them.
Gene
Gene
Old 09-21-2013, 06:00 PM   #8
1974 Argosy 20
Kooskia , Idaho
You will need the reversing switch kit from FF. About $25 each. They will email you the instructions as to how to do it. The instructions also have the wiring schematic. It is hard to understand without that sheet.
If the little rocker switch which shows open or blocked does not do anything, you have another problem with the motor or wiring which controls the automatic opening sequence and rain sensor if you have one of those.
Old 09-21-2013, 06:17 PM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Look at the model number that is printed on the side of the fan motor. Then compare that number to the models shown at Fantastic Vents webpage (FanTastic Vent - Home Page)
From there you can figure out what functions your fan should have.
I have just this week been in contact with a customer service rep by both email and telephone. They are quick to respond (next day to email and immediately to phone during business hours). I lost one of the dome covers while traveling this week. They sent replacement lids for both of my 12 year old fans at no charge. I paid shipping only.
Alan
Old 09-21-2013, 06:21 PM   #10
Thanks all.
That may be the case where that rocker is for the rain sensor.
I will call them on Monday to get the skinny on this device.
Old 09-21-2013, 07:48 PM   #11
Master of Universe
Gene's Avatar
It is easy to get confused with all the controls on ours—temperature sensor, rain sensor, fan speeds, etc. Your sounds similar. I find myself squinting into the sun to see what does what every time we take the trailer out because I forget what they do. Maybe Apple should have designed the controls.
Gene
Gene
Old 09-22-2013, 06:07 AM   #12
2005 28' Safari
saline , Michigan
Gene
And then, after you figure it out again, don't let your wife touch it. All the switches will be out of sync :-)
Kosm1o is offline   Reply With Quote
Old 09-22-2013, 09:14 AM   #13
Master of Universe
Gene's Avatar
She remembers it better than me. Like lights she turns them on and I turn them off. Perfect relationship.
Gene
Gene
Old 09-22-2013, 09:33 AM   #14
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Gene
Ya think? LOL I still have no idea what my controls mean, and I have to twiddle and fiddle to figure out how to get what I want. I now leave it to my wife. I think the use of "glyphs" instead of words is a BIG MISTAKE. I know everyone LOVES these, but I think the design of the controls is very poor.
mstephens is offline   Reply With Quote
