Old 10-31-2012, 04:22 AM   #1
Fantastic fan broke... Thoughts?
I had left the cover of my Fantastic Fan open a couple of inches to let the heat out, but we were expecting rain so I went to shut it. Its a manual close unit.
As I turned the handwheel the top kinda juddered and the slammed shut.
I thought it felt odd, so I tried to open it again, but nothing.
Finally found time to get up on the roof.
You can lift the lid now with no resistance, and looks like something broke on the lift arm, or the pivot fell out.
Fixable?
Old 10-31-2012, 05:01 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Replace it with a MaxxAir fan with a built-in rain hood.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-31-2012, 05:22 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Call Fantastic t 810-724-3818, tell them your lift arm broke. They will send you a replacement, usually for nothing more than the cost of postage.
Old 10-31-2012, 06:08 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
So true! Fantastic Fan has excellent customer service. Don't be surprised if they get the part to you last week. They are just that good.
5 meter Langford Nahanni
Old 10-31-2012, 06:14 AM   #5
Lily&Me's Avatar
Normal , Illinois
Ditto.
They sent us a complete, new install kit, no charge whatsoever.
Mggie
Old 10-31-2012, 06:27 AM   #6
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
FF Service...
The pin worked it's way loose on ours after 5 Seasons.
An emergency campground repair using a small machine screw & nut with Loctite solved the problem.
After contacting FF to let them know of my concern, (no mention of a replacement, as the repair had already been made), a new updated arm assembly was in our mailbox a day later.....no charge.
They also had previously replaced a cracked cover after three years because of improper hinge install....no charge.
Old 10-31-2012, 07:12 AM   #7
dznf0g's Avatar
Oswego , Illinois
I had similar story on my SOB. Motor assembly quit (lift motor) after several seasons. Pieces arrived N/C.
-Rich-
Old 10-31-2012, 10:37 AM   #8
Awesome info, thanks Peeps!
I have no idea which model it is because despite my thought to do so, I didn't photograph the label up top..
Am I correct in saying I have to take the vent off the roof to access the broken part?
I am asking because I better order a new gasket if I do.
Old 10-31-2012, 11:18 AM   #9
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Ditto
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 10-31-2012, 11:46 AM   #10
I wish I had the money!!!
Old 10-31-2012, 12:07 PM   #11
dznf0g's Avatar
Oswego , Illinois
No, I don't think so. From inside the AS, take the screws out that hold in the fan assembly (not the surround). The whole thing will hang from the wires (support them with a coat hanger or the like) and you can work on the mechanism from there.
-Rich-
Old 10-31-2012, 12:10 PM   #12
dznf0g's Avatar
Oswego , Illinois
Actually, upon further review, the ruling on the field may not stand. Does your manual knob fit into a sub-assembly which screws into the bottom (inside) of the fan? If so, I think you can reattach the lift arm (or replace with new parts) by just removing the 2 screws there.
-Rich-
Old 11-01-2012, 09:01 PM   #13
Fixed it!
Awesome info peeps!
Dznfog, your info was spot on...
I removed the inner raise handle, and then the 4 screws holding the trim panel, and let it hang down.
Instantly, I could see the roll pin was pushed off to the side...
I removed the assembly..
Lift mechanism with pin out of place!
It seemed a little loose, so I tweeked the roll pin open a little with a flat screwdriver, to make it a tighter fit.
Put it in position on the arm and pinched the pin back thru with pliers.
And put it back in position.
Fixed!
just missing a couple of screws...
As always, great info and I thank everyone for the input!
Reassembled it all, and
Old 11-02-2012, 02:42 AM   #14
2005 19' Safari
GLENDALE , AZ
It might be easier to just replace the bug screen. The new ones don't have screws and just snap into place. Also, the new, round plastic ring covers up the old (empty) screw holes.
I think the screen is only about $10-15 at most RV parts places.
