Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 02-10-2004, 06:07 PM   #1
David Hall
David Hall's Avatar
Profile:
Fantastic Fan # 2
Hello All, Thanks for all the past help and now I have another question for you. I install a fantastic fan it the front of the 61 overlander, 26 foot last week and now Camping World has a sell starting Thursday with them on sell for less than 100 $, My question is, should I put another fan in the rear, does two fans make that much difference. As of yet I have no AC in the overlander. Thanks in advance for the information.....Dave...
David Hall is offline   Reply With Quote
Old 02-10-2004, 06:10 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I hear that if you have 2 fans and put one on pull and one on push, that there is a great deal of airflow throughout the trailer.
Might be a wise investment if you don't have A/C.
Uwe
Old 02-10-2004, 06:54 PM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Regardless which features it has, having two fans is fantastic!
With both on it can be like a wind tunnel in the coach if set on high. One is good, but now that I've seen how two work, with anything larger than a 22' unit, two should be standard equipment!
Old 02-10-2004, 07:22 PM   #4
j54mark
Profile:
It depends upon your window configuration and preferences. On our '85 Sovereign 25' I was disappointed at the airflow from the rear vent through the front Fantastic Fan. However, when I cracked the back window open the flow was as strong as I could ever want it.
If you don't like to open the rear window, or don't have a good large one, then you really would need the two fans, one blowing and one drawing. If, like me, you have a good large window, and don't mind having it open, then the single fan has approximately half the noise and power draw of two.
Mark
Old 02-10-2004, 07:27 PM   #5
johnbaker
johnbaker's Avatar
Profile:  1978 Argosy 30
Dallas , Texas
Images: 11
FANTASTIC
While at Jackson Center in August, I asked our service advisor about replacing the living area light/fan with a skylight, he said most people replace light/fan with a Fantastic, I decided to wait but now that Camping World has this great deal, I'll reconsider. Do you think they can do a good job on the Airstream?.
We have a Fanastic in the bedroom. Our Texas summers will require the A/C but we have situations in the Spring & Fall where e could enjoy 2 Fantastics!
John Baker
1978 Argosy 30
Hensley
Excursion
johnbaker is offline   Reply With Quote
Old 02-10-2004, 07:33 PM   #6
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Fantastic Fan # 2
Greetings Dave!
I had two Fantastic Vent Fans installed in my '64 Overlander in '99 at the WBCCI International Rally in Dayton. I have absolutely no regrets - - the fans make Rallys a pleasure - - one simply did not move enough air (especially in the bedroom area during the night). I went with the reversible fans that included the rain sensor, and often leave them on thermostatic control much of the summer - - the fan in the bath is normally set for exhaust while the fan in the front living area is set for intake. When the trailer isn't being used, I just crack open the jalousie window in front to allow for air intake. When camped, I usually open the jalousie windows next to the door and just barely open a window over each of the beds.
Good luck with your decision!
Kevin
Kevin D. Allen
AIR #827
Old 02-10-2004, 09:06 PM   #7
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Keep in mind having two fans also allows you to run one opposite where you are living at the time. So if we are watching TV and temps only require one fan to be on, we run the back fan and leave the front off. Vice versa at bed time.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 02-10-2004, 09:39 PM   #8
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Take 2
We have 2 fans and we also have 2 cats. We can stop for a meal in all but the hottest weather by running one fan in and one fan out. It allows us to keep the windows closed for security.
Also nice at night in an unsecured spot such as a truck stop to keep the windows closed up.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 02-10-2004, 09:56 PM   #9
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
We are going to get one in our Safari for now, A/S asking $450.- installed. The one at C/W now is $209.- + install, may do that & do both. What do you think?
BTW, John, where do you keep the litter box? We have only one cat now but she is coming on our extended trips in the 25 Safari.
RivetED is offline   Reply With Quote
Old 02-11-2004, 05:20 AM   #10
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
CW is going to give you grief on the install fee. Even though they say it is X to install it, their install pricing is for box RV's not Airstreams. There is a set of photos on the forum that details hoe to do it. If you are the least bit handy with tools and not afraid to get on a ladder this is a DIY job.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 02-11-2004, 05:46 AM   #11
Silvertwinkie
Aluminut
If you have Airstream do it, you will find that the units are both exhaust only at this point. It could be different on the Classic line, but I when I ordered it at the time of construction of my Safari, it was $285.00 then or like you said $450 after the fact.
Vicki at Airstream told me in October of '03 that Airstream was going to go with the exhaust only units once the current stock of pusher/puller units was out. On some units however, it is an RVIA code not to place an intake near an wastewater vent pipe. There is a certain distance that is required.
At first I thought I had a pusher/puller in front, but sure enough after getting familiar with the new coach, they are in fact both exhaust.
Old 02-11-2004, 06:46 AM   #12
overlander64
Anna , Illinois
Images: 104
Fantastic Fan # 2
Another thought for those who might be planning to attend the WBCCI International Rally in Lansing, Michigan this year. Fantastic Vent has always had a factory representative at the International Rally as well as an installer. They have offered very reasonable "installed packages" during the Rally. I had both fans installed on my Overlander by the factory representative at the '99 International Rally in Dayton, Ohio. I am planning to have the factory representative install a Fantastic Vent in my Minuet at the International Rally in Lansing (the Minuet is so small that it only has one roof vent). Some years, the waiting list can become lengthy for the Rally Installation packages so it usually pays to shop and arrange installation early in the Rally.
Kevin
Kevin D. Allen
AIR #827
Old 02-11-2004, 07:12 AM   #13
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
You know the two fans on my '01 Safari were exhaust only and I really didn't feel that that diminished my satisfaction level of the fans. In cases where I wanted air to come in the hatch, I set the fan thermostat to open the hatch but not run the fan. The other fan running and exhausting air would suck air through the open hatch.
If you think about the physics the difference in performance in that scenerio would not be that diminished over one fan in exhaust and one running in an intake mode. You can only move so much air through those 2 openings.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 02-11-2004, 08:33 AM   #14
Pahaska
Pahaska's Avatar
Images: 12
The litter box goes in the shower with a rug under it so that we can shake out any spilled litter when we need the shower. With the sliding bathroom door, there is no access problem. With a swinging door, I guess I would have to put in a cat door.
The cats are a joy to travel with and have made the trailer a second home The old cat spends his time on the duvet on the queen bed watching the world out the rear window while the young cat watches the world out the front from the back of the sofa.
John W. Irwin
