Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 08-23-2005, 02:29 PM   #1
Devoman
Airstreamin and luvin it
Commercial Vendor
Devoman's Avatar
Profile:  2005 25' Safari
Panama City Beach , Florida
Thumbs up Fantastic Fan
What do you all think of this?Is it worth it?
http://cgi.ebay.com/ebaymotors/FAN-T...spagenameZWDVW
Blue Numbers and Signs
PURCHASE HERE
AIR#8855
Devoman is offline   Reply With Quote
Old 08-23-2005, 03:38 PM   #2
Pschoerrn
Pschoerrn's Avatar
Profile:  1971 29' Ambassador
Klein Denkte , Germany
Hi Devoman,
thats a very good price, but you need the "Airstream Garnish" for a proper instalation as the Fantastic Vents Garnish is for a flat roof and ceiling and as you know the Airstream ceiling is slightly curved.
I ordered two Fantastic Vents 6000 rbta with the double insulated smoked dome and Airstream Garnish from Adohen Surply for $218.99...
Including shipping them by airmail to Germany the are still $356.00 cheaper than buying them over here...
Maybe I should start to import them...
BTW nice Tow Vehicle!!! Although we are in Volkswagen County the Touareg is much cheaper in the USA then here... Maybe we have to re-import one???!!!
Bjoern
Björn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owners of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just haven´t met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 08-23-2005, 04:15 PM   #3
SilverRanger
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
Devo,
You're going to love that rain sensor. I was skeptical at first, and was hesitant to leave the vent open when we weren't in the trailer. But we had a very light shower one day when I was in the Bambi, and the vent closed right away.
SilverRanger is offline   Reply With Quote
Old 08-23-2005, 04:32 PM   #4
Devoman
Commercial Vendor
Devoman's Avatar
Fan
Would you know if it is already wired up for a fan to be put there or does it need to be wired and where to?It looks to be a fairly bit of work but would not be that bad though.Unless I have to wire it everywhere then it will probably take some time to do.Thanks
PURCHASE HERE
AIR#8855
Old 08-23-2005, 05:01 PM   #5
SilverRanger
1968 24' Tradewind
Milton , Delaware
Mine came with the fan already installed, but knowing Airstream, I'd bet the wiring is there. Check your fuse panel to see if there is any circuits dedicated to a ceiling fan. I just checked mine, and the fan is on circuit # 4 (brown wire/20 amp fuse) with the AC and the TV jack.
Old 09-06-2005, 06:56 PM   #6
Devoman
Commercial Vendor
Devoman's Avatar
fan
Would anyone know for sure if the wiring is already there.I just dont want to take it apart and then mess something up in the process just to be safe.Thanks.
PURCHASE HERE
AIR#8855
Old 09-06-2005, 08:34 PM   #7
Turtle
Turtle's Avatar
Profile:  2004 16' International CCD
Arcata , California
I wired a Fantastic fan into my 2004 16' CCD. The wires for it were right there in the ceiling when you remove the factory crank-up vent. The install was easy-peasy. Jamie
Turtle is offline   Reply With Quote
Old 09-06-2005, 08:37 PM   #8
wingfoot321
Profile:  1987 29' Sovereign
Sparta , Tennessee
Devoman,
My 1987 was wired. I think someone will tell you all the new airstreams are wired. Send a email to airstream. You should be able to remove the inside cover for the existing vent and locate the wires. Mine were running front to back close to the vent.
The $180 is the same price that Camping world had the 6000 for last year. I would be sure I am getting the warranty from the seller.
These fans are over hyped. They are cheap plastic, the motors are small and the dome sticks trying to open. I am alway fussing with mine whether it is the sticking or trying to get the thermo calibrated for the temp range that I anticipate on a particular day. It is nice to be able to go away and have the dome close in case of rain. It does allow you to vent the trailer and not leave the windows open to get rain in.
wingfoot321 is offline   Reply With Quote
Old 09-07-2005, 05:46 AM   #9
Devoman
Commercial Vendor
Devoman's Avatar
Fan
Are the fans always put in the front or put in the back.I just need to be sure so i dont take the wrong one apart.
Or do they just wire all of them all.Thanks.
PURCHASE HERE
AIR#8855
Old 09-07-2005, 06:19 AM   #10
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Motor just crapped out in mine. I hate to call them, because they probably will send me a new fan motor free. They have sent me so much free stuff, that I feel guilty asking for something else.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 09-07-2005, 06:45 AM   #11
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
You're going to find 12 volt wiring within easy reach of BOTH of your vents. Are there 12 volt lights nearby? That's where you get the electricity, if there isn't just a wire taped inside the hole.
Second, I got mine installed at the Fantastic vent factory, yes the factory. And it IS easy. If I had known how easy, I would have done it myself.
As for vents on both front and back, yes you can do it. Ask Silvertwinkie, he had his installed at the AS factory that way. You may need to check into whether or not you want the back just on exhaust, since an intake direction might suck in sewer gas from your waste vent pipe.
And Pick, don't worry about parts. That's their philosophy, their version of marketing is to provide the best service in the industry to their customers. Spares are considered in their marketing budget. Works for me!
JOhn
AYRSTRM2 is offline   Reply With Quote
Old 09-08-2005, 02:43 PM   #12
Pschoerrn
Pschoerrn's Avatar
Fan-tastic Vents
Wow, what a great (fantastic) company that is...
We ordered two Fantastic Vents 6000 rbta (with rainsensor and all that stuff) and got them last week. After installing them I realised that the Vent-motor is perfectly working , but it was not possible to open the dome automatically with the lift-motor. Everything else is working great but it seems that the liftmotor isn´t getting any electricity. I have no clue why!! Shelley from the Tech. Department at Fantastic Vents provided me with all information I asked for and even answered the really stupid question from me with a great patience.
All her answers didn´t help and now she sends us two new complete switch assemblies to Germany - for free.
Thats a great customer service in my eyes, as it is not clear what happend!! If I would have had the same problem with a german product, they would have tried to say that it was my foult and it would have been very hard to get new parts for free.
I´ll send her the "old" and maybe damaged parts back for their product development to see what was wrong...
Only thing I can say about them is - great product and a great company... Wish everyone would react like them!!
All the best from our side of the big pond.
Bjoern
Björn H. Adam
unknown irish
davetheairstream
Old 09-08-2005, 03:02 PM   #13
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Having had your same Bambi and now having a 25' Safari, I can tell you first hand, don't even think twice about....get two if you can. They are *fantastic*! In all seriousness, we love both fans we have in the Safari. The rain sensors work awesome.....I was out in the field doing some work when it started to pour....high tailed it to the Safari only to find that the vents closed all by themselves without a drop of water in the coach.
You won't be disappointed with fantastic vents...and their customer service is excellent!
Old 09-08-2005, 03:56 PM   #14
Devoman
Commercial Vendor
Devoman's Avatar
fans
So where is a good place to purchase these from.Should I use the links posted earlier?Thanks
PURCHASE HERE
AIR#8855
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 06:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 06:29 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
