Old 10-20-2010, 08:30 PM   #1
HCR
HCR's Avatar
Livingston , Full time traveler
Fantastic brings air "in" only
No owners manual from PO. Believe I have the 5000RBT model after checking FF website.
Fan moves in only one direction--what I assume to be direction switch has no effect.
Suggestions?
HCR is offline   Reply With Quote
Old 10-20-2010, 08:54 PM   #2
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
The plastic inside the switch likely cracked and the spring popped out. Call Fantastic Vent and they will send you new parts free of charge. The vent is guaranteed for life. Same thing happened to me in June and I just called them again because the mounting shrouds have all cracked where they screw in because of the curvature of the ceiling. No questions asked, FV shipped me 2 new shrouds with a curve made especially for older Airstreams free of charge.
4RXLA is offline   Reply With Quote
Old 10-20-2010, 09:34 PM   #3
_
a/s only installs FFs with 1way switches, blowing OUT.
IF the ff has a 2 way switch, it (the switch) was installed after purchase.
it is possible someone simply reversed the wiring to blow IN only...
or that the 2way switch is kaputt.
if u don't have the install instructions they are downloadable,
and it might be worth fiddling with.
but i agree call the FF folks and they will make it right.
top notch customer service is what they really provide.
cheers
2air'
Old 10-21-2010, 10:56 AM   #4
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
Check with fantastic fan Corp. It probably needs a new switch or
A wire has come off the switch. I'm quite sure there is life time warranty on certain parts. Parts I needed were free of charge.
william Haym is offline   Reply With Quote
P-30 Dash Air Conditioner and "H" valve smily Mechanics Corner - Engines, Transmission & More... 19 10-24-2015 09:59 AM
What is a "fantastic fan" ?? Brucep Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-06-2010 07:40 PM
