Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 04-17-2002, 11:32 AM   #1
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Fan-tastic Fan installation
Does any one know if the Fan-tastic Fan requires an Airstream specific mount to properly fit the curvature of the roof or does the standard catalog fan fit properly?
I just seem to recall reading somewhere that they make a special mount and trim just for Airstream.
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 04-17-2002, 01:52 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
You would need to contact Fantastic, but they do make a trim piece just for airstreams and if I remember correctly they will send it to you for free.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 04-17-2002, 06:18 PM   #3
rdm
rdm's Avatar
Profile:
Adohen supply Company carries the fantastic fan for airstream coaches and trailers at the best web price. You can call 1 440 937- 5694 or the link below
http://members.aol.com/adohen1/
Ray
rdm is offline   Reply With Quote
Old 06-17-2002, 09:12 AM   #4
Dwight
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
What are you doing with your old roof vents when you change fans? I am looking for A/S rood vent units to repair my units (the ones with the built-in skylight).
I am also looking for new or used Lindeen vent covers to add to my trailer.
Dwight is offline   Reply With Quote
Old 06-17-2002, 10:40 PM   #5
66TradeWind
66TradeWind's Avatar
Profile:
Images: 22
Fantastic fan trim
I had a Fantastic Fan installed in my former '60 Overlander at the International Rally last summer. They found the Airstream specific trim was not needed on mine. Perhaps the roofline was flatter then.
After visiting the rally we travelled in extremely hot weather and found the FF was great for air circulation. Their suggestion is to have the fan set on exhaust and keep all the windows closed except for a slightly open window at the furthest point from the fan. (hopefully in the shade) When we tried it you can feel the air current as the fan draws cool air into your unit. They said you could not cool it as effectively with many windows open.
On the other hand if you are driving down a dusty road a few miles you can have the fan draw air into your unit and create positive pressure to avoid dust entering the unit. If you do it they cautioned that the fan vent was fully open so the cover is rigid. When the vent is only partially open it will "flap" in the wind and could be damaged.
Terry O'Neill
Calgary, Alberta, Canada
WBCCI 4786
VAC
http://pages.sprint.ca/Streamsite/main.html
66TradeWind is offline   Reply With Quote
Fan-tastic Fan Installation With Photos Dabler Roof Vents, Skylights & Fans 9 09-09-2007 09:18 PM
Installation of fantastic Fan David Hall Roof Vents, Skylights & Fans 8 01-19-2004 06:18 PM
Fan installation Rob Roof Vents, Skylights & Fans 11 09-03-2002 06:28 PM
Fan Tastic Fans Gordon Watt Roof Vents, Skylights & Fans 2 06-17-2002 07:39 AM
