Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 04-19-2002, 09:28 AM   #1
Gordon Watt
Gordon Watt's Avatar
Profile:
Fan-Tastic fan install
I own a 1979 - 31 ft Soveriegn and have two Fan-Tastic fans to install.
The front vent is wired for a fan. Are the other two vents wired for a fan. The other two vents at this time have no fan installed.
Gordon Watt is offline   Reply With Quote
Old 04-20-2002, 09:24 AM   #2
apple 1
Profile:  1996 30' Excella
Brighton , Michigan
Gordon,
I don't believe the other two vents have power to them. If you pull the inside trim you might find wires there for power.
I spent yesterday installing a Fan-Tastic fan in the front vent replacing the Airstream vent and the light fixture under it. I had planed on a 1 to 1 1/2 hour job, and took 2 1/2 hours just to remove the outside cover and sealer.
It sure is a great fan a lot better than orginally installed by Airstream.
apple 1 is offline   Reply With Quote
Old 04-21-2002, 03:46 PM   #3
Gordon Watt
Profile:
Thank you for the information and the bad news on the time element. I guess it would be a one hour job if the rivets were all out before hand. I' mjust going to start the install now.
Old 04-30-2002, 06:46 PM   #4
66TradeWind
66TradeWind's Avatar
Profile:
Images: 22
Wink Hi Gordon
Welcome to the Forum, I'm a fellow Canuck from Calgary.
Terry O'Neill
Calgary, Alberta, Canada
WBCCI 4786
VAC
http://pages.sprint.ca/Streamsite/main.html
66TradeWind is offline   Reply With Quote
Old 05-01-2002, 04:45 PM   #5
Gordon Watt
Profile:
Hi Cowboy:
I just moved my Airstream to Thompson for the summer,,,, if it ever comes. There is a huge pile of snow up there yet. I flew back to Winnipeg today and sit till the weather warms up north. I fly water bombers for the province and there ain't much need for me up north just yet.
Old 05-02-2002, 10:19 PM   #6
66TradeWind
Profile:
Images: 22
Unhappy
Still waiting for summer to get working on my trailer. Snow flakes are falling as I write
Terry O'Neill
WBCCI 4786
VAC
Old 05-02-2002, 10:29 PM   #7
Gordon Watt
Profile:
YUK! It's coming to Winnipeg after the heat wave of +20 rolls through tomorrow.
Old 05-02-2002, 11:09 PM   #8
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
It was 95F here in Texas today
Spring only lasted 2 days this year.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 05-03-2002, 07:18 AM   #9
Gordon Watt
Profile:
Unhappy
31F here this A.M. To bad you have to put up with all that heat.
I used to go to DFW every spring for recurrent training on the jet I flew. Nice weather usually with horrendous thunderstorms.
Old 06-03-2002, 09:16 AM   #10
LKappenman
Finally Retired
Profile:  , Washington
We purchased the fan from CW and I called the company and they are sending out a "airstream garnish" no charge. When it gets here is there any thing else I should know? Does the space in the galley area of a 1983 310 MH accept this new fan? Or should I just pay CW the 55.00 to do it. They are booked til July 5th. Also getting up on top would it help if I put a carpeted board up there?
Dave and Louise
#2852
Finally Retired
LKappenman is offline   Reply With Quote
Old 06-03-2002, 04:19 PM   #11
Gordon Watt
Profile:
Fan Install
I haven't gotten around to intalling the fan as my trailer is in Thompson Manitoba and I am not.
Acording to the instructions some metal cutting is required. Carpeted board sounds like a good idea.
Old 06-03-2002, 06:30 PM   #12
66TradeWind
Profile:
Images: 22
install
I had a Fantastic Fan installed by them at the International Rally in Sioux Falls SD last summer. This was on my former 1960 Overlander. They had a promo at the rally for free install. It only took them about 1/2 hr. Shows how much practice helps.
Terry O'Neill
WBCCI 4786
VAC
Old 06-03-2002, 11:26 PM   #13
Gordon Watt
Profile:
Thanks for your info.
A friend of mine from Winnipeg had one installed at the same place last year at the same function I believe..... He has one of those rich people 34 footers.
Old 06-20-2002, 11:21 AM   #14
Gordon Watt
Profile:
I am happy to report, I have installed my fan-Tastic fan with no trouble as long as you have the tools.
To get the old vent off, I used a standard flat carpenters chisel to remove the aluminum rivets. There is a little bit of metal trimming..... no big deal. A new light has to be installed also. I put in a flourecent light fixture.
It operates as they say it does.
I think one is enough, so, I just happen to have one for sale. It is still unopened in the box.
Fantastic fan install questions Mike B Roof Vents, Skylights & Fans 6 03-03-2004 07:03 PM
A Few Notes on Fantastic Fan Install Pick Roof Vents, Skylights & Fans 10 06-24-2003 06:26 AM
HOT Topic for the summer-Air conditioners-Best/worst? thenewkid64 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 05:55 AM
Fan Tastic Fans Gordon Watt Roof Vents, Skylights & Fans 2 06-17-2002 07:39 AM
