04-04-2011, 07:06 PM
#21
1991 34' Limited
Teeswater
, Ontario
Fantastic Fan Install
We have 2 fantastic fans to install this spring. I found this video very informative. Helps to ease my mind re cutting the aluminum, watching this video.
Did anyone have difficulty with the included gasket, or would TremPro 636 work just fine without the gasket?
Thanks and good luck!
06-26-2011, 06:20 AM
#22
1967 26' Overlander
1953 17' Clipper
Mendon
, Vermont
Great video. Big help, thanks!
06-26-2011, 06:23 AM
#23
Retired.
, At Large
I only use the gasket when installing on SOB trailers and motor homes. It works well on them, but not so much on aluminum.
07-06-2011, 08:29 PM
#24
1971 23' Safari
Marietta
, Georgia
What do you use in place of the gasket? I'm planning to install one (or two if I'm lucky) Fantastic vent(s) tomorrow.
Thanks!
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
07-06-2011, 08:50 PM
#25
1978 31' Excella 500
Venice
It wouldn't hurt to round the corners when you cut the larger hole-relieves stress.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
07-21-2011, 07:31 AM
#26
1971 23' Safari
Marietta
, Georgia
Another question on the Fantastic Vent (FV) install. After removing the original vents is it necessary to reinforce the area between the outside and inside skins before installing the Fantastic Vent? The original vent has a fair amount of reinforcement (aluminum) built into the housing whereas the FV doesn't. If reinforcement is necessary what do you folks use?
Thanks!
- David
07-27-2011, 01:19 PM
#27
1991 34' Limited
Teeswater
, Ontario
Hi David ... my husband didn't use reinforcement when replacing as he says that the fan was installed directly alongside a supporting beam / channel which supported the wires along the top. Hope this helps.
08-15-2011, 10:32 AM
#28
1971 23' Safari
Marietta
, Georgia
This past Sunday I removed the rear vent in our Safari and replaced it with a Fantastic Vent. Removing the original vent and installing the Fantastic Vent wasn't the problem, it's just time consuming. Figuring out a stable way to get and stay on the roof without causing damage to the roof was the issue for me. I used my Gorilla ladder behind the AS to put stuff on the roof and add padding and support for the Werner ladder. I placed 2 - 2x4's with carpet on the Werner ladder to enable me to sit on it. The Werner ladder will lock in an L formation, so I used the Gorilla Ladder to place the foam padding and support in place before I maneuvered the Werner ladder up top. It worked well.
https://picasaweb.google.com/1179857...CP6NnPyImNKlBg
The rear vent has no electricity, so I tapped into the light fixture next to the vent. The vent works great. The final photo in the link above so the installed vent, but it needs to be cleaned up.
Now, it's time to figure out how to do the front vent as I have a TV antenna blocking my access...
- David
08-15-2011, 11:41 AM
#29
1976 31' Sovereign
Bothell
do these fans make a big difference on temp in the trailer? do you find that you don't have to run the A/C as much? and if you are boondocking, can you use the fans for any lenth of time?
I'm very interested in getting a couple of these fans too, that video is very nice. problem that i see for my AS is that it's got only one battery. It's new to me, so i'm not sure how long the battery will last under normal usage without hookups, and of course the fan takes juice to run.
Anyone have any experiance boondocking without a solar hookup and using these fans? not sure i can convince myself to install them, if i can't use them. Otherwise, your install looks amazing Pickerdd!
Did you want fries with that?
