04-14-2010, 08:08 PM
1965 26' Overlander
Scottsdale
, Southwest
Drill through new Astrodome???
Just got our new 14x14 and 14x26" Astrodome replacements for my 65 Overlander and when I read the instructions included with the rivots I about had a heart attack! They instructed me to drill through the dbl layer of the vent and use a sealant to weatherproof. I though you would rivot the hardware to the single interior layer of the vent cover not all the way through the brand new vent.
These are brand new through InlandRV. Anyone install these before? I went through 5 pgs on the forum and can't quite find any good examples.
Confused...
04-14-2010, 08:14 PM
Corona
Confused...
The double layer of plastic provides double the holding power for the pop rivets.
It was intentionally designed to do exactly that for extra security.
Many thousands have been fastened the way the instructions specify.
04-14-2010, 08:36 PM
1965 26' Overlander
Scottsdale
, Southwest
Andy - do I install the rivots from the exterior (top side) of the vent or the interior (bottom) side. In other words, am I holding the rivot gun in the airstream or up on a ladder on the roof (I actually removed the hardware to grease and for ease of install so not literally on the roof).
What sealant do you recommend?
04-14-2010, 10:21 PM
Corona
The very best installation, is to have the rivet head on the top of the vent covers, the rivet going thru the cover and the operator, and a 1/8 inch washer around the rivet body on the inside of the covers, thatwill be on the bottom side of the operator. It's OK, if you don't use the washer, but it is best if you do so.
You can seal the rivet head with a small dab of Par-bond sealer, or if your careful, a small dab of Vulkem sealer.
04-15-2010, 05:12 PM
1965 26' Overlander
Scottsdale
, Southwest
Can these sealants be purchased locally? ie home depot or Lowes? Thanks Andy for your help.
04-15-2010, 06:45 PM
NicheVintage,
I got one of these from Andy many years ago (over 5) installed as Andy says (rivet head outsidewith a little sealer around the "underside" of the head before installing and then a dab on the center after installing) and it has worked well.
Paul Waddell
04-15-2010, 09:47 PM
Corona
I am not sure if those stores sell Vulkem or Parbond.
I never asked if they do.
Anyone else know????
04-15-2010, 09:49 PM
1964 26' Overlander
1964 22' Safari
Nashville
, Tennessee
I purchased Vulkem locally at a sealants supplier. I found it because I saw Vulkem being used to seal store front windows on install. Who knew! Anyway, if you search sealant supply in google maps, you could find a supplier who carries it.
04-15-2010, 10:48 PM
1965 26' Overlander
Scottsdale
, Southwest
Ok so picked up some silicone sealant and took the measurements and thought I was all good to go and then this! Does it ever end? Any way to repair or am I calling Andy again in the morning for another order! This darn Airstream, while a lot of fun is a real pain in the you know what!
04-18-2010, 09:15 AM
1963 19' Globetrotter
Crystal Lake
We just purchased this astrodome in white and are just this minute trying to figure out what to do with it. I told the girl on the phone that our 1963 globetrotter was inherited with a piece of plywood instead of the dome. When I asked, she said that it came with instructions and the hardware required to attach it, but we have no idea how to start. If someone has clear instructions I would really appreciate it. Still searching the archives, it must be here somewhere :-)
04-18-2010, 11:09 AM
Corona
The cover must be riveted to the opening operators.
04-18-2010, 05:25 PM
Crystal Lake
Obviously. I just wish that the promised instructions were included. We spent a bit of time looking it over, but have no idea if we should remove the lifters first- or buy scaffolding and work on it from above.. I know that this is probably a stupid question....it is just annoying when you are promised that there will be instructions on an expensive piece of plastic and just get a puzzle.... I am not even sure if we have all that we need because there is not even one diagram to give us any kind of guidance.
And where do we but the roll of foam gasket?
04-18-2010, 05:32 PM
Corona
No need to get on the roof.
Measure the distance between the operators exact location.
Mount the operators in those locations.
Add the gasket. Extend the operators somewhat
Turn the astrodome vertically, extend it thru the astrodome opening, lay it flat against the astrodome metal flange, bottom side down, position the operators, snap the operators in place.
Retract the cover as necessary, using the operators.
The key is to make proper measurements, as there are 2 different sizes of astrodome flanges or frames.
04-19-2010, 06:50 AM
Crystal Lake
Thanks Andy. You did not really answer my questions, but I guess that it must mean that I should be able to figure it out myself.
04-19-2010, 07:40 AM
Corona
What question did I not try to answer?
04-19-2010, 08:11 AM
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
If you have the original openers/lifters, then measure the distance between the lifters where the new dome will attach with the lifters in the down position. Then take the lifters out by placing a screwdriver between the lower part of the lifter and the arm on the frame of the opening that juts out and pry it off. All of the work you need to do to the new astrodome, you can do on your workbench. Once completed, the dome can be installed from inside the trailer by lifting the completed dome through the vent opening and positioning it in place.
Hope this helps and good luck.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
04-19-2010, 08:27 AM
1966 26' Overlander
1966 26' Overlander
From Parts Unknown
, Unknown
Tremco Vulkem is carried by Fastenal where you can buy it cash & carry. Find a location near you at their website Here is what they call it:
TPV626Alum-300mlC 1-partPolyurethaneTexturedMasonry | Fastenal
The masonry nomenclature denotes its the color of concrete (aluminum)
Alex Kensington, Full Timing with
Charon Henning, The Most Dangerous Beauty Alive™
1966 Safari Overlander & 1961 Safari
1956 Spartan Imperial Mansion
TCT Since 2002, 8728,
04-19-2010, 01:53 PM
Crystal Lake
Thank you Brad- that is exactly what I was wondering, and very helpful...
05-05-2010, 07:20 PM
2021 27' Globetrotter
Gulfport
, Mississippi
Check out the link in the first post of this thread, maybe it will help.
http://www.airforums.com/forums/f372...led-22287.html
05-06-2010, 10:30 AM
Crystal Lake
It is, thank you. WE have the frozen lifters off and waiting to be soaked in WD40- and we think that we have figured it out. Thank you for your replies and for this forum.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
astrodome removal
wolfpack |
Roof Vents, Skylights & Fans |
1 |
04-10-2010 09:35 AM |
Astrodome question?
PensacolaJim |
5 |
01-05-2008 11:27 AM |
Astrodome Replacement
Cochese |
2 |
09-10-2007 02:05 PM |
Been Kicked in the Astrodome
Jeffrey Stoecker |
1 |
04-19-2006 08:31 PM |
astrodome
kenlmarc |
0 |
02-27-2003 12:09 PM |
