Old 04-19-2010, 07:40 AM   #15
Originally Posted by LoriK View Post
Thanks Andy. You did not really answer my questions, but I guess that it must mean that I should be able to figure it out myself.
What question did I not try to answer?
Old 04-19-2010, 08:11 AM   #16
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
If you have the original openers/lifters, then measure the distance between the lifters where the new dome will attach with the lifters in the down position. Then take the lifters out by placing a screwdriver between the lower part of the lifter and the arm on the frame of the opening that juts out and pry it off. All of the work you need to do to the new astrodome, you can do on your workbench. Once completed, the dome can be installed from inside the trailer by lifting the completed dome through the vent opening and positioning it in place.
Hope this helps and good luck.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-19-2010, 08:27 AM   #17
TheProfessor's Avatar
1966 26' Overlander
1966 26' Overlander
From Parts Unknown , Unknown
Tremco Vulkem is carried by Fastenal where you can buy it cash & carry. Find a location near you at their website Here is what they call it:
TPV626Alum-300mlC 1-partPolyurethaneTexturedMasonry | Fastenal
The masonry nomenclature denotes its the color of concrete (aluminum)
Alex Kensington, Full Timing with
Charon Henning, The Most Dangerous Beauty Alive™
1966 Safari Overlander & 1961 Safari
1956 Spartan Imperial Mansion
TCT Since 2002, 8728,
TheProfessor is offline   Reply With Quote
Old 04-19-2010, 01:53 PM   #18
LoriK's Avatar
1963 19' Globetrotter
Crystal Lake , Illinois
Thank you Brad- that is exactly what I was wondering, and very helpful...
LoriK is offline   Reply With Quote
Old 05-05-2010, 07:20 PM   #19
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
We just purchased this astrodome in white and are just this minute trying to figure out what to do with it. I told the girl on the phone that our 1963 globetrotter was inherited with a piece of plywood instead of the dome. When I asked, she said that it came with instructions and the hardware required to attach it, but we have no idea how to start. If someone has clear instructions I would really appreciate it. Still searching the archives, it must be here somewhere :-)
Check out the link in the first post of this thread, maybe it will help.
http://www.airforums.com/forums/f372...led-22287.html
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 05-06-2010, 10:30 AM   #20
LoriK's Avatar
It is, thank you. WE have the frozen lifters off and waiting to be soaked in WD40- and we think that we have figured it out. Thank you for your replies and for this forum.
Old 05-06-2010, 11:42 AM   #21
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I would like to replace my solardome but all of the hardware is missing. Any suggestions where I can get it?
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 06-28-2011, 01:54 PM   #22
1970 31' Sovereign
farmington hills , Michigan
Images: 12
i will be replacing mine very soon.i only have one original vent with lifters.i am going to replace both small vents with fan-tastics and will use those lifters for the astrodome.just a suggestion if you plan on replacing one of your smaller vents.
manymemories is offline   Reply With Quote
astrodome removal wolfpack Roof Vents, Skylights & Fans 1 04-10-2010 09:35 AM
Astrodome question? PensacolaJim Roof Vents, Skylights & Fans 5 01-05-2008 11:27 AM
Astrodome Replacement Cochese Roof Vents, Skylights & Fans 2 09-10-2007 02:05 PM
Been Kicked in the Astrodome Jeffrey Stoecker Roof Vents, Skylights & Fans 1 04-19-2006 08:31 PM
astrodome kenlmarc Roof Vents, Skylights & Fans 0 02-27-2003 12:09 PM
