Old 07-07-2004, 07:17 PM   #1
jlawrence's Avatar
San Antonio, TX
Images: 12
Unhappy Dome from Inland doesn't fit my '59
Help!
I got a 14x14 dome from Inland and it doesn't fit the frame of my old one (which has fallen to pieces). Any ideas what I should do? The hardware doesnt look like it will easily transfer to the new dome without some serious mods.
...see attached pics
Thanks, John.
ID:	7579   Click image for larger version
jlawrence is offline   Reply With Quote
Old 07-07-2004, 08:31 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
John -
I wish I had known you were going that route. I would have suggested you measure the outside dimensions for your vent inner lip and called Inland to verify it would fit properly. I had the same thing happen with the AstroDome I purchased. I ended up making one with clear lexan and aluminum angle. PM me if you would like pictures and a cross-section.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-07-2004, 08:50 PM   #3
jlawrence's Avatar
San Antonio, TX
Images: 12
Vent problem
..as a temporary solution, I have covered the original frame with white duct tape (overlapping the edges). It will at least keep the rain out if it holds up for a while...
Old 07-08-2004, 06:45 AM   #4
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Vent cover
I cut a piece of alum. and rivetted it to the vent cover with volkem and olympic rivets. Has worked for two years.
Don
Gunnyusmc is offline   Reply With Quote
Old 07-08-2004, 06:50 AM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
It looks like you could easily make a new frame from aluminum angle, available at Home Depot. This way your new vent cover would work, and you would get the benefit of the thermal barrier these vent covers have.
You can simply cut the angle in a miter box, then use a small angle piece and a few rivets to connect the corners. Seal it with some par bond or vulkem, and install your old hardware to it.
Just a thought.....
Uwe
www.area63productions.com
Old 07-08-2004, 09:15 AM   #6
Chas's Avatar
Images: 22
I'd send it back but speaking from experience be sure to get an return authorization first.
You will be much better off just riveting a section of Lexan or even just aluminum over the old frame and reusing it. It would be much more original as well.
Chas (yes I am still alive!)
Former Airstreamer
Chas is offline   Reply With Quote
Old 07-12-2004, 04:42 PM   #7
J Lawrence
You have picture a vent cover, not a vent frame. The frame is riveted to the roof and never moved.
Your photo shows a cover, with a hinge.
You might have some off brand vent that someone installed.
I have never seen one as you have pictured.
Sheets that FIT!! dtbw 1997 - 2004 Bambi 8 09-10-2003 09:29 AM
Reese dual cam sway - fit??? Craig Hitches, Couplers & Balls 4 06-18-2003 04:50 AM
Front dome crack davidz71 General Interior Topics 30 04-29-2003 10:18 AM
Fiberglass Dome Marshall44 General Interior Topics 5 03-10-2003 06:21 PM
Will this couch fit my trailer?? JohnGalt48 General Interior Topics 4 08-07-2002 06:38 PM
