Old 08-01-2015, 09:06 PM   #1
rowesean's Avatar
1976 31' Sovereign
Morehead City , North Carolina
Question Combination ceiling light and vent replacement
I have a 1976 International 31' Sovereign. The ceiling lights in the main living area both have issues and I would like to completely replace or repair them. The main issue for both is that the cranks to raise the vents doe not work (one is completely missing so prior owner used screws into ceiling to hold it in place) and the other the crank shaft is stripped so it does not raise or lower. The one that is in the front (with missing crank) has a fan in it and one of the blades is broken off. To repair these (assuming rest of electrical and moving elements are working which I am skeptical of) is it best to just try and replace the cranks or should I find replacemetn vent/ceiling light setups? Where would I get the parts?
rowesean is offline   Reply With Quote
Old 08-02-2015, 09:21 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
A popular move is to replace the entire vent with Fantastic Fans. I am not advocating this replacement, but the point is, that there are almost certainly all the components you need to repair your vent lifters and fan assemblies sitting in some Airstreamer's garage out there. You might put a "want" ad on the the Forums Classified ads. Silver Trailer Supply also sells some used stuff, and if you are patient, you might find them on Ebay.
good luck!
Old 08-02-2015, 10:10 AM   #3
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Fantastic Vent is the way to go, check it out at Vintage Trailer Supply. Fan-Tastic Fan Vent
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Fan/light combination options dougandlori Electrical - Systems, Generators, Batteries & Solar 0 08-21-2014 06:24 PM
Combination ceiling light / vent assembly parts 1974 International Razorhog Lights - Interior & Exterior 14 03-15-2013 04:33 PM
LED Retrofit for Fluorescent Ceiling Vent/Light vswingfield Lights - Interior & Exterior 5 12-30-2012 07:36 PM
Plastic light switch for ceiling light in 1979 Sov. Bowmans Lights - Interior & Exterior 4 10-14-2009 05:17 PM
Winegard combination Satellite and TV donhardman Electrical - Systems, Generators, Batteries & Solar 3 01-07-2005 02:32 PM
