Old 08-14-2019, 09:46 AM   #1
Silver Condo III
kamadeca's Avatar
2015 30' International
Saskatoon , Saskatchewan
Cleaning Blades of Fantastic Fan
Hi folks,
Did a search for this topic but didn't come up with anything specific for our problem.
I am trying to clean the blades on our Fantastic Fan (after 2 weeks in a very dusty climate). I can take off the inner screen, unscrew the centre screw that holds the blade to the shaft, but when I try and pull the blades down they get caught on the housing inside the trailer. I have looked at YouTube and most videos just show people pulling the fans straight down - can't do it on the Airstream.
Do I have to get up on the roof and undo the motor mounts? Hope not.
Any suggestions, hints would be greatly appreciated.
Malcolm
kamadeca is offline   Reply With Quote
Old 08-14-2019, 12:54 PM   #2
2019 25' Flying Cloud
Hendersonville , North Carolina
FF blade removal
We had a 2017 23D and now a 2019 FC25 and the fan blades come right out. Remove inner screen, remove center screw, blade slides right off. I just went outside to eyeball our fans in the 2019 FC25 just to see if I could see where you might be having an issue, but no joy.
Can you get the blade loose from the shaft or is there not enough clearance?
Possibly a call to Fantastic Fan, there number is in the book that came with your AS. Have your model number handy. Maybe your fans were designed a bit different. Good luck.
uraljohn is offline   Reply With Quote
2 Broken Fan blades 1978Argosy28 General Motorhome Topics 2 11-30-2016 07:27 AM
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Bathroom Fan Blades sgray Roof Vents, Skylights & Fans 1 11-18-2010 04:00 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
