Old 08-29-2008, 06:12 PM   #1
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
center vents with lights all around
We have three vents running down the center of our unit and they have lights as well. When you take the inside cover off bulbs are the whole way around the perimeter.
Was this a standard for our '78 Excella, and are replacements available for them?
wannaroam is offline   Reply With Quote
Old 08-29-2008, 06:27 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
That is what I have on my Overlander,new covers are available on Ebay,don`t put in 1156 bulbs,they will burn cover,RV stores have bulbs with lower wattage.A lot of people are replacing with LED lights.Dave
easyride is offline   Reply With Quote
Old 08-29-2008, 07:05 PM   #3
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
We had the same ones in our 72. You can get the covers at www.outofdoorsmart.com. He is the one that has them on ebay also.
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 08-29-2008, 08:11 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I see Inland Rv has them as well, depending on which coast you are closer to.
Old 08-30-2008, 06:37 AM   #5
wannaroam's Avatar
Images: 36
I was thinking of replacing the whole unit, not just the covers (which I have). Two of these have scorch marks right where the switches are, and they don't seem to work.
Old 08-30-2008, 07:16 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
It will be harder to find and more expensive to replace the whole unit. The switches are still available from the above sources If you replace the switches, wires and lenses you will basicly have a new unit.
Lumatic is online now   Reply With Quote
Old 08-31-2008, 05:45 AM   #7
wannaroam's Avatar
Images: 36
Ok, thanks everyone.
Old 08-31-2008, 07:08 AM   #8
lynn's Avatar
These lights where called Bird Bath Lights. They were used from the seventies up through the late 90"s. Most of the components are still available through an Airstream Dealer.
lynn is offline   Reply With Quote
Old 09-02-2008, 06:18 AM   #9
wannaroam's Avatar
Images: 36
We checked them out well yesterday and they are still working; lights and fans.
But when we went to turn one of the lights off the switch was so hot it actually burnt my husbands fingers. The wiring looks to be ok; would this be due to a bad switch? Or could it be a more serious problem?
Old 09-02-2008, 06:40 AM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
I would suspect a bad switch.
If you are buying new plastic shop around. In addition to AS they are available at Inland RV, Vintage Trailer Supply and Ebay. Inland RV has the switches.
Old 09-02-2008, 06:47 AM   #11
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Wow, not to take too far off topic, but that out of doors mart website is impressive. Even have actual sheet metal and pricing on it. That place has everything!
Old 09-02-2008, 04:35 PM   #12
wannaroam's Avatar
Images: 36
Woo-hoo!
We installed the converter today and everything is working. I have an appointment for inspection on Friday, and God willing we can try it out this weekend.
A big thank you to everyone who helped us!!
Old 09-02-2008, 04:49 PM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I took the automotive style bulbs out of mine and installed a couple of compact 12v fluorescents instead. I also wired the switch so it turns on one or both. IIRC the switch has 3 on positions, I plan to use the third for a small LED to be used as a night light. I now have the low draw and clean light of the fluorescent and the look of a vintage. I plan to do a similar rebuild of the bathroom fixtures.
Aaron
WBCCI #XXXX AIR #2495
Old 09-02-2008, 07:41 PM   #14
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Was it difficult to switch to flourescent and do you have pictures of what you have done. I would like to change mine out in the Sovereign and also would like to do something with those lights in the center bath. They really aren't bright enough and when they're on you can see the wiring through the lens.
Judy At Home in Oklahoma
juel is offline   Reply With Quote
vent lights
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
Small fire at Service Center at Jackson Center hohne Our Community 32 06-07-2004 10:00 PM
New lights & Vents Herritt Electrical - Systems, Generators, Batteries & Solar 8 05-21-2004 03:07 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
