Old 06-21-2004, 08:41 PM   #1
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
ceiling vent fan question?
I was camping this weekend in hoosier national forest and because of the cool weather I opted to turn off the a/c and and opent the windows on our '77 lland yacht. I went to crank open the ceiling vents and noticed a fan in the living room vent. But I cant find the switch to operate the fan. Any one know the location or have suggestions
Thanks wayne
wayne.yl is offline   Reply With Quote
Old 06-21-2004, 08:44 PM   #2
RichardT's Avatar
Thanks wayne
It should be right next to and under the fan in the 1 inch wide ring that holds in the vent screen , unless you have the big plastic light covers like a 73, then it comes on automaticly when you open the vent, if it does not come on and is the automatic style check the fuse and the hidden switch inside the vent area.
RichardT is offline   Reply With Quote
Old 06-21-2004, 08:58 PM   #3
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
richardt, thanks for the info. Mine does have the big plastic covers and so the fan fuse is out or motor is bad I guess. I will check it out in the morning.Wayne
Old 06-21-2004, 09:00 PM   #4
RichardT's Avatar
I have had alot of Airstreams and not one had a bad fan motor, so I bet it is the switch or fuse, these things were built tough, also It would be a good time to clean the light cover and vent area while you are looking up there, as it gets really dirty sometimes.
Old 06-22-2004, 07:26 AM   #5
BDBLUEGRASS
bdbluegrass's Avatar
1975 31' Sovereign
HEBER SPRINGS , Arkansas
ON my 75 sovereign , with the large vent covers, the vents have to be completely open for the fan to come on, it activates on the very last turn of the crank.
Hope this helps
Billy
bdbluegrass is offline   Reply With Quote
Old 06-22-2004, 09:34 PM   #6
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Richardt
I have ruled out the fuse unless the fan is on a different circuit than the light. I am investigating the micro switch on the hand crank now. I need to remove the rivets that hold the fan/shroud assembly though. didn't have the right tools earlier. If It is the switch, can it be found? Thanks By the way, It is pretty dirty up there!
Old 06-24-2004, 03:49 AM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Different batting average
Originally Posted by richardt
I have had alot of Airstreams and not one had a bad fan motor, so I bet it is the switch or fuse...
I have had one Airstream, and one bad motor
Noisy Refrigerator Vent Fan rseagle 2002 - 2005 International 43 01-01-2016 07:49 AM
vent fan wiring joel Electrical - Systems, Generators, Batteries & Solar 3 07-06-2005 09:10 PM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
