Old 04-01-2010, 08:27 PM   #1
TankerIP's Avatar
2002 22' International
Caution - Keep an eye on Fantastic Vent Covers
A couple of years ago, I discovered our front vent cover completely open, the arm separated, and vent cracked as it was slammed back. I thought the storm the night before had caused the destruction. I could not remember if I had left the vent partially open or had closed it. I assumed the storm winds had "ripped" the vent cover up.
I now know that it was not the storm, but a malfunction in the raising/lowering system.
Last week on a trip I tried to raise the back vent but all that happened was the motor turning with no action. I tried to raise it manually but the handle only turned, so I figured something was worn and I would check it when we got back home. Today, dismantled the fan from inside and found that the raising handle was completely loose from the drive mechanism. It was worn, but now the vent cap could be raised by hand with nothing to keep it down. I was lucky that during the trip we didn't have rain with winds in a direction that would "pick up" the vent cover.
My suggestion is that we need to frequently make sure that the vents will open as they should. If they don't, then we need to make sure that the vent covers aren't loose. Because, if they are loose, a storm to blow open the vent and flood the trailer underneath it.
TankerIP is offline   Reply With Quote
Old 04-01-2010, 08:36 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
you may be lucky
I have found the folks at Fantastic Fans..are GREAT to work with. Call 'em and explain the problem. You may be pleasantly rewarded by their response. I know its hard to believe in these times....but there are some responsible companies out there....I think these people are. Good luck.
P.S. shut the fan tonight we are in for it tomorrow. Another fun Spring in Texas.
vent covers, fantastic fan
Cleaning Fantastic Vent Fans John S. Roof Vents, Skylights & Fans 11 10-22-2009 07:09 PM
Vent Covers Over Fantastic Fan flyfisher Roof Vents, Skylights & Fans 14 01-24-2006 03:02 PM
Fantastic Vent R&SZinser Roof Vents, Skylights & Fans 11 11-30-2005 07:56 AM
Fantastic Vent sticking 74Argosy24MH Roof Vents, Skylights & Fans 37 06-09-2005 05:15 AM
Which Fantastic Vent? uwe Roof Vents, Skylights & Fans 9 08-30-2004 09:37 AM
