Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 07-15-2008, 07:25 PM   #1
willyd
willyd's Avatar
Profile:  1993 34' Limited
2 Door Model , Melbourne Florida
Bedroom Vent Interior Cover
As I have an eye condition that is bothered by direct sunlight, I am trying to find (make) a temporary cover that is installed inside my bedroom vent so that the early morning light that comes through the vent doesn't bother my eyes. Your ideas will be appreciated.
willyd is offline   Reply With Quote
Old 07-15-2008, 07:30 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  Bay Area , California
What brand vent do you have now? What you have will make a difference as to what is suggested.
For example, if you have a Fantastic Vent, you can get a solid white cover, or a solid grey cover.
overlander63 is online now   Reply With Quote
Old 07-17-2008, 09:25 AM   #3
willyd
willyd's Avatar
I have the standard vents - even without a fan. I am planning to install fantastic fans at some point. Is there a difference between fantastic fan and a fantastic vent?
Thanks.
Old 07-18-2008, 12:03 AM   #4
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Vent Cover
Hi, willyd. I just did that. I bought a vent cover from Camping World, it was white plastic, has a cross lattice pattern look, and comes with four corner holders. I cut the cover down in size. I cut the corner holders to fit. [I made it fit so I would not have to make new holes] I used the four screws that hold the vent bezel in place. Only problem was that the crank handle was too low, so I had to remove it. Later I bought a window knob [round black plastic] Now I can have a cover on my rear vent to block the light or take it off [slide it out] and have a knob to turn the vent crank to open it. Works great.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 07-18-2008, 07:54 AM   #5
overlander63
Rivet Masher
Thanks.
There is really no difference, other than a Fantastic fan has a fan, and a Fantastic Vent is just a vent. Most people don't realize they can get a fanless vent.
You can get a Fantastic Fan from Vintage Trailer Supply with a silver lid, it blends in a little better on our silver trailers, though I don't know if they let in any light at all when closed.
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Old 07-18-2008, 11:25 AM   #6
corgikat
corgikat's Avatar
Profile:  2007 27' Safari FB SE
Mansfield , Massachusetts
Bob,
Can you post a photo of what you have done? I hate the sun waking me at 5 in the morning when I am on vacation!
Kat
corgikat is offline   Reply With Quote
Old 07-18-2008, 11:42 AM   #7
anneon
Profile:  2007 19' Safari SE
shreveport , Louisiana
If you don't want to spend any money and need a quick fix just cut out a piece of cardboard, punch a whole where the handle is. Blocks out all the sun. It usually comes out going down the road. I've used mine since I bought my Bambi. Cheap, easy and quick.
anneon is offline   Reply With Quote
Old 07-18-2008, 12:56 PM   #8
Safari-Rick
U.S.Navy Retired
Safari-Rick's Avatar
Also had problem with too much sunlight coming in during the first sun. I went to Camping World and bought the Maxair Vent Cover (Smoke color). I wanted the black to minimize the light that comes in, but the Smoke vent cover was more then enough. Mounts easily over the existing standard vent. Price was $29.95 here in SoCal. Took less then an hour to install. (Easy).
Rick )
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 07-19-2008, 12:34 AM   #9
ROBERTSUNRUS
Images: 18
Vent Cover
Hi, here are some pictures of my vent cover. It is white plastic with chrome bubble insulation on the top side. As I stated earlier, I modified it to fit useing the Airstream bezel screw locations. It really blocks out the light. Note the black plastic window knob I used to be able to slide the cover on and off because the crank handle was too low. On the cover I trimmed all four sides and re-rounded the corners. Also on the corner brackets, I cut them down a bit too.
Name:	PICT0019 (Large).JPG
ID:	64022  Click image for larger version
Name:	PICT0020 (Large).JPG
Name:	PICT0021 (Large).JPG
ID:	64024  Click image for larger version
Name:	PICT0022 (Large).JPG
2005 Safari 25-B
anyone tried this vent cover? gparker Roof Vents, Skylights & Fans 5 05-11-2008 04:42 PM
Broken vent cover? IRV Roof Vents, Skylights & Fans 15 10-14-2006 05:52 PM
Lost vent cover... 53flyingcloud Parts Archive 5 06-06-2005 09:51 PM
roof vent cover kent osborn Roof Vents, Skylights & Fans 1 11-02-2003 08:58 AM
Vent Cover - Lundeen Zed2 Roof Vents, Skylights & Fans 1 10-12-2003 01:44 AM
