Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 11-30-2005, 07:52 PM   #1
dustyrhodes
Profile:  1977 27' Overlander
Huntsville , Alabama
Question Bathroom fan vent?
I am presently in the top down stage of restoration, attempting to seal the leaks. There is a bathroom vent/fan that I would like to replace but am not sure where to start looking, or what the original may have looked like.
At present, I put aluminum tape over the opening which peaks out on the heavens with a burned out fan underneath. The opening is only about 4 inches, although I have not measured. The top is open and there is no hat, no cover, no nothing.
Does anyone have knowledge of this fan? with what appartus I can replace it, where I find it, what am I asking for, and what the original looked like in case I have to improvise. It can't possibly have been an open hole to the elements. I am mystified>
dustyrhodes is offline   Reply With Quote
Old 11-30-2005, 08:08 PM   #2
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Do a forum search on "bathroom fan" and go down to my post (davidz71) on "polishing again". You will see a couple pictures of what is in my '77 Excella 500.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-01-2005, 09:17 PM   #3
dustyrhodes
Craig,
Thanks for the lead. I am still unclear on what exactly is supposed to be in the fan that prevents the water from pouring in. Mine is identical to yours on top. Inside I don't have that cover but fail to see how that prevents water from flowing in. Is there something that is supposed to be inside on top of the fan that opens when you switch on the fan. Mine is a completely open system. Of course the plastic cover that is in your picture on the inside is missing, but even that would not stop the rain.
And anyway "Who'll stop the rain?"
Jennifer
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 09:01 AM
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 07:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 06:35 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 11:44 PM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 07:29 AM
