Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 06-21-2007, 11:46 AM   #1
Profile:  1971 23' Safari
Beaverton , Oregon
Bathroom Exhaust Fan for 71 Safari
I recently discovered that the bathroom exhaust fan for my 71 Safari was lying on the bathroom closet floor, unmounted and disconnected from power. I couldn't tell where it was originally mounted and where it exhausted to. I can't imagine that it just exhausted into the closet, but I don't see a hole for it to exhaust to.
Does anyone know where it was originally mounted and where it exhausted to?
Thanks for your help!
Pete
ID:	39677   Click image for larger version
rrpranch is offline   Reply With Quote
Old 06-21-2007, 12:52 PM   #2
Profile:
Pete, I know nothing about your model and year trailer, but in my trailer that is the tubing to distribute the hot air from the furnace to the the various outlets in the trailer, and the fan is atteched to the furnace to carry this out. FWIW.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 06-21-2007, 01:47 PM   #3
Groveport , Ohio
Bath fan
Hello Pete, The fan in my safari is in the ceiling. If you need a picture let me know.
bertro is offline   Reply With Quote
Old 06-21-2007, 01:53 PM   #4
Beaverton , Oregon
Yes, I'd like to see a photo, if it's not too much trouble. Although, as you can see from the photo the electrical wires seem to exit the shell right at the floor.
Thanks!
Pete
Old 06-21-2007, 02:31 PM   #5
Groveport , Ohio
Fan pics
Here you go Pete. I'm missing a latex cover that keeps the bugs and cold air out.
ID:	39684   Click image for larger version
Old 06-21-2007, 02:42 PM   #6
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
My '72 GT it's mounted on the floor in the closet.
Fyrzowt is offline   Reply With Quote
Old 06-21-2007, 03:05 PM   #7
Beaverton , Oregon
Bertro, thanks for posting the photos! But I have nothing like that either inside or out on my Safari (California built).
Fyrzowt, are you a firefighter and it's like "Fires out"? Does your fan just exhaust into the closet or is it vented outside?
Thanks a ton for the help, guys!
Pete
Old 06-21-2007, 03:27 PM   #8
Fyrzowt's Avatar
Images: 8
Pete
Hi Pete, yes I'm a Firefighter, and that's the way I say Fyrzowt.
The fan intakes air from the bathroom next to the toilet, carries it through the flex hose and dumps it out the bottom below the floor. You can't see the exit in the photo, but it's the metal housing on the far side, opposite the red drain valve handle.
Dave
Old 06-21-2007, 06:21 PM   #9
Beaverton , Oregon
Ok, so half of our closet floor has been replaced with new flooring and I looked at the exterior beneath the trailer to see if there was an exhaust port there. and found what looks like several modifications to the underside.
Does your trailer have an exterior vent for the exhaust or was it just exhausting into the belly pan?
Thanks!
Pete
Old 06-21-2007, 10:36 PM   #10
Fyrzowt's Avatar
Images: 8
Pete, sorry for the delay, I've been away from the computer.
It appears that it just exhausts into the belly pan.
I have that oval shaped bulb-out under mine too, I haven't investigated it's purpose.
Dave
Old 06-22-2007, 10:18 AM   #11
Beaverton , Oregon
Dave,
It seems to line up with the bathroom drain pipe. Maybe it's just there to allow more room for the trap? It looks to me like that whole section was cut out and replaced on mine. But if you have it too, maybe it's original.
I'm not too thrilled with the idea of venting warm, moist, pungent air into the belly pan. That seems like bad design to me. Now I have to decide whether to replace it or not. Do you use yours very often and is it helpful?
Pete
p.s. I apologize if this thread seems to be getting a little to personal.
Old 06-22-2007, 10:46 PM   #12
Fyrzowt's Avatar
Images: 8
You're probably right about the drain pipe trap. Mine has a couple of layers of aluminum that look like a patch, like yours. I think it's original.
I don't use the fan often, it can help - depending on how much work there is to do.
Dave
Old 06-26-2007, 07:57 AM   #13
Cos
Profile:  1973 21' Globetrotter
Middletown , Rhode Island
On my '73 GT the fan is also mount to the floor and vents out the bellypan through a steel fitting (which is bad shape and explains why it may have been removed in another trailer).
Cos is offline   Reply With Quote
2003 Safari 25 Melvin P. Thorpe 2003 Safari 24 09-15-2007 11:53 AM
re-plumbed 67 Safari tod47d Plumbing - Systems & Fixtures 4 01-30-2006 12:04 PM
Electrical problem--99 safari Andrew Carey Electrical - Systems, Generators, Batteries & Solar 2 11-16-2002 03:04 PM
Furnace Exhaust niftypkg Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-27-2002 10:19 AM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 06:49 PM
